Dimensions to brake lines?
Old Sep 12, 2004 | 10:53 PM
dvsmode's Avatar
I ended up twisting off the lines in an attempt to replace the caliper. Do you guys know the dimensions to the brake lines? I dont really care for the length rather the od/id of them. thanxs fellas!
Old Sep 12, 2004 | 10:55 PM
dvsmode's Avatar
sorry for the double thread mods. can anyone help me?
Old Sep 13, 2004 | 09:58 AM
Snrub's Avatar
I believe a 3/16" line is what you want. Bring what you have of the line to any auto parts store. They'll match it up for you and you can pick the length you want.
Old Sep 13, 2004 | 10:39 AM
YearsOfDecay's Avatar
Locust of the apocalypse
From: Directly above the center of the earth (York, PA)
I just did the ABS removal.... Its 3/16.
Heres the catcher.. I think the flares might be different... I used a standard flaring tool with a 45 degree flare.... i've flared plenty of brake lines so i know how to do it...
When i put it together... every stock connection leaked until I backed the nuts off and retighted them several times, each time they went a bit further until they finally locked up. No leaks after that.. The aftermarket "T" fitting i used for the front brakes worked perfectly the first time.
looking at an old stock flare, it appeared to be a steeper cone than the 45 i was using, maybe a 60?? That would explaing why the bolts took a while to get tightened properly, the flares were fitting themselves to the seats....
Can anybody clarify if the stock Mazda fittings are something other than 45 degree flares??
Old Sep 26, 2004 | 11:20 PM
Barwick's Avatar
SCCA Rookie
wtf? I've got an '89 and the 3/16" doesn't fit right. I think on my '90 it was a M10, but even the writeup says 3/16"... but they just don't fit at all with the 3/16" ones.
Old Sep 27, 2004 | 02:45 PM
Barwick's Avatar
SCCA Rookie
anyone know what size they are for sure?
Old Sep 27, 2004 | 07:27 PM
Barwick's Avatar
SCCA Rookie
found out they're M10 x 1.0 fittings, but there's NO FREAKING 3-WAY FEMALE TEE that fits that. Crap.
Frisky Arab
13
Aug 18, 2015 05:30 PM
GrossPolluter
Aug 16, 2015 09:50 AM
