can i use a +42mm wheel?
Old Sep 12, 2004 | 06:38 PM
bcbjj's Avatar
i have read here that people recommend not going overm 32mm or so on the offset? is that the max i can go or can i use 42mm? 90 vert if that makes a difference or not. thanks
Old Sep 12, 2004 | 06:53 PM
Yes, you can use 42mm with no problem provided the width is 7.5 or less and you use a 205 tire. Some 215 tires will rub the spring, some will not depending on alignment. If you have coilovers, you'll have more room for larger tires.
Old Sep 12, 2004 | 07:05 PM
gergrx7's Avatar
Boosting Again
i run +42 with a 7 inch wide wheel adn 225/45s up front adn dont rub
Old Sep 12, 2004 | 09:19 PM
I use +42 x 7.5" adr limited wheels, tires are 215 x 40 x 17" on my 1990 gxl coupe ok , but later added spacers to bring the wheels out a bit to look better and add some space between the coil overs, bought the cheap *** universal spacers on ebay and later made some decent 5 bolt ones at work ..
Old Sep 12, 2004 | 09:24 PM
If your looking at the 17" with the + 46 Adr limited wheels on ebay, you have to make spacers for the center caps on the front, or go without the caps because of the wheel shafts stick out too far , don't relly look bad without the center caps ...
Old Sep 13, 2004 | 05:06 PM
bcbjj's Avatar
http://cgi.ebay.com/ebaymotors/ws/eB...category=43957
i was hoping to use those.
Old Sep 13, 2004 | 07:26 PM
gergrx7's Avatar
Boosting Again
they will work fine
FB_Frank85
Sep 6, 2015 11:29 AM
