Help Please: Oil Pressure Gauge Not Working
I installed my motor and the oil pressure gauge is not working. Its b/c i dont have one of the two wires hooked up. I have the wire that goes to the unit hooked up, can anyone tell me where the other one goes???
Trending Topics
no I mean do you have manual pressure gauge so you can test your oil pressure to make sure that it really doesn't have 0 psi of oil. Also was this gauge working before???
The OEM oil pressure sender only has one wire going to it- it grounds through its threads on the side housing.
So, make sure your engine grounds (bonding jumper at the tranny-firewall) are good, and make sure your sender threads are nice & clean (no teflon tape wrapped around them)...
On S4 cars, the sender wire is yellow/red...
Also make sure the capacitor (bolts to the clutch slave cylinder for its ground) wiring is not shorting to ground...
