wanting to get a wideband but don't want to pay a fortune
Old Sep 10, 2004 | 10:04 PM
hondahater's Avatar
spending too much money..
what do you think of this:
1. http://www.urdusa.com/Merchant2/merc...gory_Code=PERF
I like this one because you can use the stock o2 sensor location, no need weld in another bung. I can find for about 275 plus shipping
or this one
2. http://www.zeitronix.com/
or there is anohter one that the guys on this forum use but it is a bit much, however I don't want to get something so cheap that it is inacurate. This one goes for 279 before you get the lcd and since you need the lcd it bumps the price to 399
Old Sep 10, 2004 | 10:45 PM
Falcoms's Avatar
kill it with BOOMSTICK!
The first one looks like the best deal, and it looks like if you want to do some tuning, that would be good enough to get you in the ball park. You would still be better off with a day at the dyno with a f/a mix sniffer to tune it properly for the best performance with least emissions. Unless you have a fully adjustable and controllable aftermarket EMS, you probably don't need to go to that extreme (and expense). If you just have a piggyback system or, as I see in your sig, a SAFC, you should be able to tune it good enough with that. It just takes longer, and alot more patience.
Old Sep 10, 2004 | 11:36 PM
hondahater's Avatar
thanks man after searching on this site for the past 2 hours I haven't seen a negative thing about it. THey also have a converter that will convert the signal from .1v narrow band gauges to a .5v so that your narrow band will now see the correct wideband signal.
Old Sep 11, 2004 | 01:43 AM
Impreza2RX7's Avatar
The PLX wideband is a good deal also..
Old Sep 11, 2004 | 07:40 AM
hondahater's Avatar
yeah the plx is the one I'm talking about!
Old Sep 11, 2004 | 08:25 AM
shiftnmadkwik's Avatar
SUPERnaturally Aspirated
or for 350.... http://www.innovatemotorsports.com/lm1.php
Old Sep 11, 2004 | 10:24 AM
hondahater's Avatar
I've heard of alot of people having problems with the lm-1 of course the amount of users that have the lm-1 are alot more than plx users. I do like the fact for 350 you have data logging witch is really cool!
Old Sep 11, 2004 | 10:33 AM
hondahater's Avatar
just found this and it says "Sample and store air/fuel ratio, and up to five additional inputs (RPM, MAP, MAF, TPD, etc)" so I was wondering why you would need the rpm converter??? Thanks.
damn I can't make up my mind!!!!! I can either spend the 275 on a plx or bite the bullet and get an lm-1 with the rpm converter and a heatsink bung extender for a grand total of 518 oh plus the stainless steal bung for 8 bucks.......damn I don't know what to do. It's not like my car is really heavily modified its just that I would like to keep an engine withought blowing it up. Probably the plx would be good for my application I would just like to have the data logging however if you get the plx with data logging its like 499. ANyways sorry I'm just thinking out loud.
Old Sep 11, 2004 | 10:44 AM
sub9lulu's Avatar
i m getting a wideband also
innovate is going to be my pick
i did my searching on the single turbo forum, looks like innovate is best bang for the buck
Old Sep 11, 2004 | 10:57 AM
hondahater's Avatar
what are you getting with it sub??? are you getting the rpm converter??? I'm just thinking if you don't have it and you are logging your data the only thing it is going to log is your a/f ratio numbers however that won't help much if you don't see what rpm your at as well. or does it collect the rpm data as well without rpm convert??? IF it does then I'm going lm-1 as well.
Old Sep 11, 2004 | 11:39 AM
KNONFS's Avatar
B O R I C U A
Proud PLX device user here, basically I choose it because of its size\display
Old Sep 11, 2004 | 11:40 AM
hondahater's Avatar
did you get the one with data logging?
Old Sep 11, 2004 | 11:57 AM
KNONFS's Avatar
B O R I C U A
Nope, I am data loggin to the E6K
Old Sep 11, 2004 | 12:55 PM
hondahater's Avatar
yeah that makes it easy crap! can anyone answer my question about the lm-1 being able to data log a/f and rpm withought the rpm converter or does it only log a/f number and not rpm without the rpm converter
Old Sep 11, 2004 | 01:00 PM
sub9lulu's Avatar
well i have a LT8 sitting around that i m gonna use
edit, using the method of this post
https://www.rx7club.com/microtech-111/wideband-datalogging-280674/
Old Sep 11, 2004 | 11:49 PM
hondahater's Avatar
**** it I'm getting the plx at 275 you can't beat it!
dkwasherexd
May 27, 2017 04:51 AM
Microtech
Aug 23, 2015 11:04 AM
