FD motormounts
Old Sep 3, 2004 | 12:40 AM
Godzilla-T78's Avatar
FD motormounts
Curious why the fc 20b mounts wont work in the fd? I have seen the 13brew drop dirrectly into a fc so why couldnt it work likewise with engine mounts? Only downside i could see is it sit higher than if you made custom subframe. Please give me more information on this. Im collecting information to putgether a web faq and start my own project. Also what is the issue with the oil pan?
Old Sep 3, 2004 | 03:11 AM
RETed's Avatar
Uh, FC versus FD has radiacally different engine mounting systems.
Uh, it's not a direct swap.
In fact, it's more of a pain in the *** to swap the 13B-REW FD3S engine into the FC3S versus either of the Cosmo motors, especially with the help of pre-made engine mounts adapters.
Um, this has been covered many times in a lot of the FD threads in this section.
-Ted
Old Sep 14, 2004 | 03:45 PM
speedkrazy85's Avatar
does anyone know of a post that has pic's and info on that kind of swap.
(13brew)
Old Sep 14, 2004 | 04:01 PM
felix_is_alive's Avatar
i had a thread on here ....not that detailed , but should help , do a search under my name in the 20b section ...it should pop up, and i used the 20b brackets ,and the fd mounts
Old Sep 15, 2004 | 03:06 PM
93BlackFD's Avatar
built my own engine
just stack your 20B with 13B rear plate, problem solved, get a custom oil pan, and you're set
Old Sep 15, 2004 | 03:12 PM
if you go with this procedure you will have to cut the uim , otherwise youre hood will not close (unless you have a gigantic hood scoop a la MAD MAX ) also there are a few tricks regarding this custom oil pan when clearing the steering rack , oh and bye the way , you will also have to match port the plates as the ones for 13b and 20b have different sizes
Old Sep 15, 2004 | 03:14 PM
Red-Rx7's Avatar
Administrative Me
When it is all said and done, it is about twice as expensive & work than buying a subframe/spindle kit. But, if you want it done right..
Blastfastrotary
Jul 8, 2015 09:48 PM
RRTEC
Jul 27, 2009 11:57 AM
wanklin
Jun 25, 2006 06:26 PM
