Engine Management Forum Use this area for discussing Haltech, Wolf 3D, Power FC, AEM and any other aftermarket ECU upgrades. Help/Questions/Tuning
Plug for Dizzy/CAS Hole?
Old Sep 2, 2004 | 09:46 PM
renns's Avatar
I'm running a crank-fired (ok, e-shaft-fired) ignition system in my 13B. I've discarded the distributor, and replaced it with an S4 CAS. I'd like to go the next step, and remove the CAS, and replace it with a suitable plug. I may have to machine up something to suit, but I thought I'd check and see what others have done in this instance.
Any recommendations?
Old Sep 27, 2004 | 10:45 PM
You can press fit a large enough freeze plug or just use a block-off plate with sealant and nut. I've seen it work both ways. I personally use the freeze plug. It makes for a cleaner install.
-Brad
_Tones_
May 25, 2021 05:37 AM
13
Jan 9, 2018 11:19 AM
ZacMan
Sep 19, 2015 09:20 PM
mulcryant
Sep 9, 2015 05:24 PM
