Anyone know pin id's for ACV Valve??
Old Nov 24, 2001 | 02:55 PM
Bambam7's Avatar
I came, I saw, I boosted.
I removed my ACV Valve, so obvioulsly I unplugged it from the 2 connectors, and I don't like the fact that I always have a code 30 and 33 now... does anyone know what pins to jump/ground/charge to fool the ECU into thinking that the AVC solenoids are still hooked up?
Thanks a lot
Old Nov 25, 2001 | 01:47 AM
Keith's Avatar
I would suggest you plug in 30 ohm 10 watt resistors into each connector. This would fool the ECU. IMHO, I would just unscrew the 2 valves from the ACV and plug them into the connectors (plugs fit, leads are insulated, and they just screw out of the ACV). Good luck!
Irv, Keith's dad
Coochas
Oct 3, 2015 04:49 AM
Sh00bs
Oct 1, 2015 11:57 PM
