exterior keyhole light
Old Nov 23, 2001 | 07:33 PM
ronarndt's Avatar
Question exterior keyhole light
Do all of the 93 production run Touring models have the exterior keyhole light on the driver's door? I can not see on the lock cylinder, when viewed from the inside, where a bulb would be, unless it is a small neon one. Did not want to take the lock assembly apart if there is no bulb inside. Or does the whole thing need to be replaced to change the bulb? Any suggestions?
Old Nov 23, 2001 | 10:00 PM
CantGoStraight's Avatar
What's your point ?
Changing bulb is easy
When you remove the door handle you should be able to follow the wires to the little buld in the lock assembly. I purchased a package of small 1.5 watt lamps (not positive of wattage) from radio schack with a green, yellow, and red bulb in it. I just cut the wires and soldered the new bulb wires on to the original wires. I put the green one on mine as it's Montego Blue, and did a red bulb for a friend of mine (his is red) it was like $1.50 or so for the bulbs, once you take the door handle loose you'll see how it's held in.
acha3
Sep 6, 2015 08:14 AM
