The single is here!!
Old Aug 29, 2004 | 11:59 AM
BoostorLose's Avatar
Bridgeport Anyone??
I just received my new single turbo, TO4R, 1.0 A/R divided housing. I am putting my own kit together and I was wondering what gets removed when I install the single turbo? I know the Air Pump and all emmissions controls are kaput, but what of all the solenoids, rats nest, and the like? Anyone who has done this before who could help me would be really awesome. Thanks a lot guys. I will post pics of the new turbo ASAP. Thanks again.
Mike
Old Aug 29, 2004 | 12:39 PM
ZoomZoom's Avatar
SEMI-PRO
pm "CCARLISI"
Old Aug 30, 2004 | 08:55 PM
Snook's Avatar
Tony Stewart Killer.
keep the purge solenoid
its really hard to go over everything. you dont need any solenoids under the uim though just the purge thats near the oil filler
ill help if you have some real questions
zoom zoom have you tuned your car with the oem 2mm seals i heard some people had problems with them and they are in my car too 1300 on the engine
Old Sep 1, 2004 | 11:11 AM
Bridgeport Anyone??
Does anyone know how much boost the 2mm seals will hold? I was only planning on running around 16psi until I rip the motor apart...again.
Old Sep 1, 2004 | 11:27 AM
CCarlisi's Avatar
Rebreaking things
Demetrios runs over 30psi on them. Seals don't typically buckle because of boost, they break from detonation. Rebuilding your motor isn't going to make it less prone to damage from detonation. Ask zoomzoom, he has seen a motor or two....or three fail from detonation with less than 1,000 miles on the clock
Old Sep 1, 2004 | 11:29 AM
Snook's Avatar
demetrios runs 30-35psi on them
we are talking about the new 2mm 2 piece from mazda
some people reported problems with warping with a certain type of port
Old Sep 6, 2004 | 10:42 AM
Bridgeport Anyone??
I am only planning on running a large streetport, which will be complete in a few days and no more than 18psi, 15psi for daily driving. I hear the 2mm seals will hold this. My fuel system is also pretty beefed up to make sure detonation or fuel starvation do not rear their ugly heads. Again thanks for all the info guys, it's really helpful.
Mike
Old Sep 6, 2004 | 12:47 PM
FC Alex's Avatar
Do we have start another why you don't need 3mm seals thread? You don't need 3mm apex seals... they help only a marginal amount. Trust me I wouldn't boost 30 plus psi on my motor if I didn't trust 2mm apex seals, we've never had a problem with them. Considering my tuners race car runs 7's on 2 mm apex seals. But, you cannot deny the fact that 3mm do help with little detonation's or when you lean out a little. In those slight cases they do take a hit, and your motor will be fine... but it comes down to you realizing that the car needs to be tuned to save your motor. Sorry I started to go off on a tangent.
Alex
Old Sep 11, 2004 | 11:35 PM
Bridgeport Anyone??
Not a problem to go off on a tangent. And to answer your question, no , we do not have to start another thread on 2mm vs. 3mm. If you read my post carefully, I was just curious what people had boosted the 2mm seals to. I personally am a fan of the 2mm, and see no point to 3mm seals. I will be taking care of the motor so detonation will not be a problem. Thanks for the info however, I was not aware that the 2mm have been boosted to 30 plus psi. Thanks for the info Alex. Take it easy.
Mike
sukimoto
Rotary Car Performance
Oct 26, 2015 02:37 PM
demetlaw
Oct 2, 2015 06:22 PM
93FD510
Oct 1, 2015 02:00 PM
