Turbo shaft play: acceptable limits?
Old Nov 23, 2001 | 01:31 PM
bob13bt's Avatar
Fixed the wheelhop
I just picked up an 87 Turbo II. The turbo has a little bit of lateral play in the shaft. When is this unacceptable? When it gets so noisy it sounds like its coming apart? Or until it stops making boost? I plan on a new one soon, just wondering if it is ok to run like it is. Thanks
Old Nov 23, 2001 | 04:03 PM
Scott 89t2's Avatar
SOLD THE RX-7!
I'm sure it's fine. it just won't last as long as one that doesn't have any and might take a split sec longer to hit full boost. you know it's gone if it hits the sides when you move it back and forth, or here very bad noises while boosting.
C. Ludwig
Jan 30, 2019 06:31 AM
