2nd gen tranny in a GSL-SE
Old Aug 26, 2004 | 06:34 PM
caddy83's Avatar
What do you need to do to replace your tranny with a 2nd gen transmission? Please give me the exact procedure. Thanks. I have a 1985 GSL-SE. I will need a tranny soon and have access to a 2nd gen tranny. What will be the difference between a non turbo tranny and a turbo tranny. How will this affect the performance of my car. Keep in mind, my 13b engine is a recent rebuild, no carb but stock fuel injection system(engine is less than a year old). Like I said, I have access to both these trannies.
Old Aug 26, 2004 | 07:22 PM
BARF1's Avatar
Who are you?
Good Lord I hope somebody reponds, I need the same info also, yes, quite obvioulsy i'm bumping this post.
Old Aug 26, 2004 | 07:40 PM
bouis's Avatar
All you have to do is swap tail housings & shifters.
Edit: really, that's the exact procedure.
Old Aug 26, 2004 | 07:47 PM
lovintha7's Avatar
Suicidal Death Missile
Turbo tranny = stronger
Old Aug 26, 2004 | 07:49 PM
Rex4Life's Avatar
RX-7 Alumni
Check the sticky page 1st Gen FAQ. My own writeup and Setzep's cover all the details.
Old Aug 26, 2004 | 07:55 PM
caddy83's Avatar
What sticky page are you talking about. Please be more specific. Where do I go for this info. Thanks
Old Aug 26, 2004 | 07:59 PM
bouis's Avatar
They're not talking about turbo transmissions. You don't have to do any cutting or welding or anything to put an NA FC tranny in a FB.
Old Aug 30, 2004 | 07:03 PM
BARF1's Avatar
Who are you?
I did a search found a writeup about putting an entire turbo II motor and trans into an FB but I'm looking to just put the trans in because mine is grinding like bitch when shifting into 2nd and 3rd. Is a 2nd gen NA trans a direct bolt in? Will I need a different size driveshaft or trans mounts? If it's a direct bolt in (hopefully) then all of the worries in my life will be solved.
Old Aug 31, 2004 | 12:13 AM
bouis's Avatar
Tail housing & shifter. That's it.
Old Aug 31, 2004 | 08:09 PM
BARF1's Avatar
Who are you?
I assume the tailhousing is a different lenght on the 2nd gen trans and I need to change it with the one currently on my car so I can use the same driveshaft? When you say change the shifter do you mean I have to drop the one from my current trans into it, why's that, is the 2nd gen shifter much longer/shorter? Any help is appreciated.
Old Aug 31, 2004 | 08:42 PM
bouis's Avatar
Actually I think the tail housings might be interchangable. Don't quote me on that. You can see for yourself, since you'll have to take them off to get the shift-rods out.
The shifter is externally mounted and bolted to the top of the tail housing. You'll want the whole shifter housing and shifter from the first gen tranny as well as the first gen shifting rod. I think it's six 10mm bolts to swap them over. Real easy.
Rotospectre
Sep 13, 2015 11:22 PM
