Mounting carbs on 13b's
Old Aug 26, 2004 | 10:25 AM
MG-X7's Avatar
Unhappy Mounting carbs on 13b's
Hey guys/gals,
Just wondering if anyone has run into the same problem as I am and how you got past it. I purchased a Carter AFB (Edelbrock Performer is the same) 625 CFM carb to put on my car. It's a 4 port 13b with a stock intake manifold, and I'm running into a problem.
The mechanical secondaries stick out too far and I can't get the carb on since it hits on the frontplate just below where the coolant inlet is. The picture below shows the area. The car currently has the exact same Carter AFB on it but is a 400 CFM carb. The previous owner managed to cutdown and shorten the throttle shafts so the secondaries don't stick out as far. But this looks like it'd be a serious pain in the ***.
My options as I see it are to
1) figure out how the hell to shorten the shafts,
2) get 2 2" spacers to lift the carb up past the problem area (though this would introduce other issues like air cleaner/hood clearance and moving the power curver),
3) sell it and get a weber ($$)
4) see if I can remove enough material at that spot on the front plate to get the clearance.
Any suggestions?
Old Aug 26, 2004 | 10:40 AM
vipernicus42's Avatar
Rotoholic Moderookie
625CFM???
Are you running a bridge port?
Sorry, can't help with the problem.. just wondering why in God's name you're running such a huge carb. If your engine is stock port, you're gonna have some major problems getting it runnign well..
Jon
Old Aug 26, 2004 | 11:01 AM
MG-X7's Avatar
It's a street port. Racing beat sells the 600 cfm holley for streetported 4port 13b's, so I got a good price on the carter and figured why not try it.
Old Aug 26, 2004 | 11:21 AM
Slammed_GSL's Avatar
The carb won't fit on the stock manifold,you need the Racing Beat intake or a spacer. I have a 4port 13b and mine had spacer that was cut to fit the carb.
Old Aug 26, 2004 | 11:41 AM
Jeff20B's Avatar
Lapping = Fapping
Your air cleaner assembly is awfully tall. Just use a spacer and shorter air cleaner. Let us know how it changed the powerband. Another thing you might want to consider is since your engine has a carb, it'll benefit greatly from a direct fire ignition system.
Inspector71
Aug 26, 2015 12:06 PM
KAL797
Test Area 51
Aug 11, 2015 03:47 PM
