Sponsored by: CARiD
inlet manifold questions
Old Aug 25, 2004 | 11:14 AM
lySdEXiA's Avatar
Newbie
i have 2 simple questions, relating to inlet manifolds.
1: are 12A and 13B manifolds interchangable?
2: to run an aftermarket carb, ie a weber or delloretto etc. is a custom inlet manifold required, or can u use the stock one?
Old Aug 25, 2004 | 07:22 PM
rotarygod's Avatar
Rotors still spinning
1: If you have an adapter then yes.
2: The stock one will not work on the 12A cars. You'll need a new one. If you have a GSL-SE, you'll need a new upper manifold.
C. Ludwig
Jan 30, 2019 06:31 AM
