radio quality degrades over 30 minutes
Old Aug 24, 2004 | 07:31 AM
Mr. Gadget's Avatar
Older than Dirt
89 Vert
Kenwood 5025
Pioneer speakers in door and dash new wires puled to both
Stock headrest speakers - wired direct using factory wiring (jumpers in plug at amp)
All factory amps unplugged or removed
Unit has sperate ground installed, all wires soldered and covered with shrink
Over the course of about 30 minutes the output degrades in quality to the point where its hard to hear and what you do hear is poor quality. With a CD I can change tracks and everything comes back to normal. Radio or sattelite, must turn off unit for a few sec's and then it goes back to normal.
Any ideas?
Old Aug 24, 2004 | 02:12 PM
tobecontinued's Avatar
Do I read correctly that you have 3 pairs of speakers hooked up to the head unit? If so, How? How many ohms are the factory head rest speakers?
You could be overheating the head-unit if you are powering too many speakers (esp. any lower than 4 ohms)
Old Aug 24, 2004 | 03:51 PM
Mr. Gadget's Avatar
Older than Dirt
actually 4 pair
2 in the doors (4 Ohms)
2 in the dash (4 ohms)
2 each in the head rests
Old Aug 25, 2004 | 12:43 AM
SPNumber3's Avatar
Thats only 3 pairs, but it does sound like your over heating the unit like tobecontinued said, maybe if you have 2 pairs running off the same channel that could be your problem, best bet is to write up a wiring diagram so we can see it better or give a more detailed explanation of how everything is hooked up.
Old Aug 25, 2004 | 01:00 AM
diablone's Avatar
Originally Posted by SPNumber3
Thats only 3 pairs
Two in each headrest, two headrests.
Old Aug 25, 2004 | 02:19 AM
SPNumber3's Avatar
i thought about that after i already hit the post button.
Old Aug 25, 2004 | 10:13 AM
Mr. Gadget's Avatar
Older than Dirt
dont have a graphics program at work, however the wiring is simple
LF output controls the L door and dash speaker
RF output controls the R door and dash speaker
LR controls the left headrest speakers on both seats
RR controls the right headrest speakers on both seats
all are + to + or - to - as indicated on wiring or speakers
no amps used (headrest speaker amp shot, therefore bypassed).
Old Aug 25, 2004 | 10:52 AM
spot_skater's Avatar
The Cause of Death
maybe you should use an amp if you're using that many speakers
i've got six speakers, and push two of them with an amp
Turblown
Vendor Classifieds
Oct 17, 2020 03:25 PM
izzolaw
1st Gen General Discussion
Sep 27, 2015 08:33 PM
