water temp guage location
Old Nov 22, 2001 | 11:36 AM
puma's Avatar
canadian monster
would it be a good idea to take the temperature on the throtle body rubber coolant line so that i don't have to run the line in front of the engine?
i could also take a guage with shoter water line.
thanks a lot
puma
Old Nov 22, 2001 | 06:51 PM
7-sins's Avatar
thats not paint....
Post up here what you end up doing. I am trying to find a spot where I can tap into a rubber coolant line. I went with the autometer mechanical water temp gauge, woops. The line is short and the sender is huge. I guess thats what you get for $50.
Old Nov 22, 2001 | 08:08 PM
just get longer wires at home depot or something, and it will just fine at the throttle body coolant line
Old Nov 22, 2001 | 10:35 PM
CantGoStraight's Avatar
What's your point ?
Mechanical Temp Gauge
AFTERBURNER.....he said it was mechanical so the only wires would be for the gauge lamp !!!!!
Old Nov 22, 2001 | 11:40 PM
7-sins's Avatar
thats not paint....
hehe
I think I have an idea on the line to tap into. In this picture attached, circled in red, is this where the throttle body coolant line is?
Old Nov 23, 2001 | 03:26 AM
hapa's Avatar
That's the correct hose to plug into, but according to some members on the big list, if you install your gauge there you will h2o temps that will be around 5 degrees less than if you mounted on it on the water pump housing. Good luck.
eric
Old Nov 23, 2001 | 11:26 AM
Re: Mechanical Temp Gauge
Only looked at the first post, no mention of a mech.
Old Nov 23, 2001 | 12:57 PM
7-sins's Avatar
thats not paint....
Thanks eric, I will probably install there. I have my PFC to tell me temps too. I just need something for a quick glance every now and then.
Old Nov 23, 2001 | 01:21 PM
Want2race's Avatar
Bigger and better things
if i did my mods again i would not get an extra gauge... I would linearize my stocker ( really easy to do!) and buy a temp switch that was set for 210 degrees... Then run that to the low coolant bulb or maybe the cruise control light ( since i dont have cruise..) and that way i would only know when the temp is beyond 210!
sherff
Feb 24, 2019 12:09 PM
Snoopy FD
Dec 8, 2015 01:45 PM
josef 91 vert
Aug 29, 2015 12:22 AM
befarrer
Microtech
Aug 22, 2015 05:52 PM
