Sponsored by: CARiD
push start
Old Aug 23, 2004 | 12:21 PM
chrisw80's Avatar
push start
Hi
(I have a 1987 rx7 turbo very nice) and the engine is running way to ruch is there anyway to lean it out? Also its not staring in the morning when i need to drive it. But it will start if i push start it down a hill and shift it into 2end and pop the clutch and than it will start good all day long from there. Dose anyone know how to fix this thanks.
Old Aug 23, 2004 | 01:02 PM
Jeff20B's Avatar
Lapping = Fapping
Your starter might be tired (old and slow). When they age, it takes more voltage to produce the same amount of cranking RPM as when they're new.
Or the ignition key switch no longer works correctly in the 'START' position.
Those are the two possible problems you've got to work with. I can't think of anything else.
Old Aug 23, 2004 | 01:25 PM
Syonyk's Avatar
Does it not crank at all, or crank slowly? If it's cranking slowly, go down under the car & clean off the connections to the starter. Clean the ground connections in the car, too.
It sounds like the starter's getting old though, and having problems when cold. Either get good at push starting it, or take the starter in to get it tested. Any halfway decent auto shop will be able to test it for free.
-=Russ=-
Old Aug 23, 2004 | 10:58 PM
Theres a lot of stuff you could do. You need to take the intake manifold off and have all your injectors cleaned, you need to get a new starter and battery, replace your spark plugs and have it tuned by someone who knows how to lean it out with hurting your engine. After you do those things you should have your problem solved.
Old Aug 24, 2004 | 02:21 AM
t-von's Avatar
Rotor Head Extreme
How long have the spark plugs been in their? Mileage? You could also have a faulty TPS.
Old Oct 3, 2004 | 08:37 PM
cloud791's Avatar
not tryin to jack ur thread, but i am kinna having the same problem. i can hear it crank but it just wont start without having me stomping on the gas pedal. i am driving a 91 na, can anyone help. thx
Old Oct 3, 2004 | 09:57 PM
fc_dorifto's Avatar
is the rpm gauge jumping when you try to start the car ????? if not, it may be your crank angle sensor .....
Old Oct 3, 2004 | 10:09 PM
cloud791's Avatar
i can hear the engine "churn" like it is trying to start but, its like there is nothing to light things up.
Old Nov 19, 2007 | 10:09 PM
ghalee-fc's Avatar
im having the same problem, but i dont hear the engine turn over.
do i need a new starter?
whinin
Mar 30, 2019 07:53 PM
rx7shirley
Sep 2, 2015 02:11 PM
