fc seats in an fb
Old Aug 22, 2004 | 11:09 PM
The Unsent's Avatar
Space Cowboy
fc seats in an fb
would anyone know if seats from an fc will fit in an fb? what all work is needed to do it?
-E
Old Aug 22, 2004 | 11:15 PM
faye x7's Avatar
brilliantly stupid
I've read they are a direct fit.
Old Aug 23, 2004 | 12:18 AM
Gregs's Avatar
i have fc seats in my car, direct bolt in
Old Aug 23, 2004 | 01:28 AM
gonzz's Avatar
I installed seats from a 89 RX-7. Direct bolt in
Old Aug 23, 2004 | 01:38 AM
1badFB's Avatar
GSSL-SE
i found that when i swapped over my turbo II seats into my FB that one of the bolts on the drivers side didnt quite line up correctly, however it was just far enough from the other hole that drilling and tapping it out worked using the same bolt
Old Aug 23, 2004 | 01:40 AM
1badFB's Avatar
GSSL-SE
if this is unusual can anyone tell me why the runner didnt line up with the same hole the original seats had, because no one else seemed to have this problem. did i install it incorectly?
Old Aug 23, 2004 | 02:38 AM
TurboIIGuy's Avatar
Driveline Killer
I had the same problem on one of my 1st gens about a year back. The runner from the seat didn't line up with the hole. Solution: I sat in the seat while I reached down to thread in the bolt by hand. I guess the pressure flared out the frame of the seat or something. Anyway it should be a direct bolt in unless the floor pan is bent or the seat rail is bent.
Old Aug 23, 2004 | 03:04 AM
jammerx7gsl's Avatar
Black Night (AKA SPAZ)
ive got red leather FC seats in my 83... The work wonderfully, and feel awsome... They beat the 1st gen leather seats 10 times over in comfort
Old Aug 23, 2004 | 05:39 AM
Gregs's Avatar
the front left bolt on the drivers seat doesnt line up, i dont even have it bolted down, the seat never moves though so i dont care
Old Aug 23, 2004 | 09:18 PM
ChasRX's Avatar
second gen seats using first gen sliders...
Here, I mounted the 2nd gen seats to the original 1st gen sliders; custom upholestry. 2nd gen seats were $50 from the boneyard, then another $200 to re-cover. I plan to use the same 1st gen sliders for new Mazdaspeed or used RX8 seats this year, though.
Old Aug 23, 2004 | 10:16 PM
RotaryRyan's Avatar
DSM
^thats a nice interior you got there!
Old Aug 26, 2004 | 11:56 PM
The Unsent's Avatar
Space Cowboy
thanks guys.
Old Aug 27, 2004 | 01:01 PM
Hadoken's Avatar
I have a question about putting FC seats into a FB. Are the FC seats any higher? As it is I don't have all that much room between the seat and the steering wheel, I have enough now as long as I tilt the seat down, but if FC seats are much higher it just won't do.
Old Aug 27, 2004 | 02:16 PM
I think they actually sit a little lower, but i could be wrong.
Coochas
44
Nov 5, 2019 11:08 PM
