pics of my new DIN panel
Old Aug 22, 2004 | 09:34 PM
ZeroBanger's Avatar
This is a plug in module I developed for my water injection kit. The first switch arms/disarms the system. The 2nd switch turns stage I off. The first LED tells you If the nozzle is clogged or that water is actually injecting, by way of a water pressure sensor. The 2nd LED tells you that stage I was activated and the 3rd LED tells you that stage II is activated.
Any opinions?
Old Aug 22, 2004 | 09:36 PM
ZeroBanger's Avatar
here is the din with the hardware
Old Aug 23, 2004 | 12:43 AM
Flybye's Avatar
It's never fast enough...
Originally Posted by ZeroBanger
Any opinions?....
One.
WHY didn't you aline the LEDs?
Old Aug 23, 2004 | 01:09 AM
SpeedKing's Avatar
Power Trippin'
Originally Posted by Flybye
One.
LOL, you noticed that too? And the switches are crooked. ZeroBanger must be cross-eyed.
Old Aug 23, 2004 | 03:28 AM
ROTORhead93's Avatar
The panel looks great, but would look perfect if everything was aligned. But still, great idea.
Old Aug 25, 2004 | 08:02 AM
forcefed1's Avatar
how are you holding the panel in the din?
Old Aug 25, 2004 | 08:28 AM
rotarynemesis's Avatar
FD Maniac
I think it would look better with them mounted on the panel because those few on that huge panel just look plain. It would look better like this.
Old Aug 25, 2004 | 03:00 PM
soru81's Avatar
Off-topic: I see you have custom painted console plastic... please tell me how did you remove the peeling overlay? BTW, didn't you use to have gunmetal interior? Thanks.
Old Aug 26, 2004 | 10:10 AM
MrRx's Avatar
Rotary on a budget
Stripper, or sand it..... I think the pannel looks great but, what rotartnemesis showed would be better looking and would allow people with the bose system to keep it...not to mention it just looks cooler
Old Aug 26, 2004 | 10:32 AM
Shinobi-X's Avatar
Sensory Experience
If the wiring that I see in Zerobangers photos in necessary, then it might present an issue trying to fit the led's and switches in the fashion that you have them because of both space limitations, and the way the panel curves towards the bottom and/or sides. It would look better though if possible.
Old Aug 26, 2004 | 10:46 AM
93BlackFD's Avatar
built my own engine
why so spaced out?
