best way to kill omp same mode?
Old Aug 21, 2004 | 04:51 AM
smooth13b's Avatar
Exclamation best way to kill omp same mode?
I have had my car for months and have never driven it. I started with a vac job and then plugs,wires,ast,ect. basicaly ive spent some cash.Anyway i finaly figured my main problem and the car has a dead oil metering pump and it is in safe mode atm.So i found out i can get a used omp and plug it in and strap it to the strut bar or whatever. Now i need to know if there is a easier ,faster or cheaper way to get rid of safe mode. ...btw does the pfc have the ability to stop the fail safe?
.......yes i realise i need to run premix with no omp , its been mixed and filled as of today
oooooooo........... if there is no eisier way im in the market for a used but fully functional omp
Old Aug 21, 2004 | 03:05 PM
smooth13b's Avatar
BTW i meant OMP SAFE MODE
Old Aug 21, 2004 | 05:27 PM
rx7raca's Avatar
wHiTe kNiGhT
I have one...I'm going with haltech so I won't be needing it anymore. pm me if you want it.
And can't you put a resistor to trick the ecu?
Old Aug 21, 2004 | 06:24 PM
yodaddy's Avatar
why the hell would you plug in a different omp just to strap it to the strut bar? there are only three bolts that hold it in, just install it completely instead of being lazy.
Old Aug 21, 2004 | 09:34 PM
jdhuegel1's Avatar
Glug Glug Glug Burp
Dude, just replace the damn thing. Don't go doing any goofy "strapping" to the strut bar. 3 10MM bolts hold the thing on, and 2 more hold on the lines. 1/2 hour tops.
You can get used ones from people that have Haltecs etc.. Don't pay too much though. Some people try to get dealer cost for them..
Good luck with the car.
Old Aug 21, 2004 | 10:34 PM
r0gu3's Avatar
Boostless FD
I have a Haltech and use my OMP.
Old Aug 22, 2004 | 03:41 AM
smooth13b's Avatar
well i wanted to run premix any way so straping it however crap it sounds isnt so bad. I might just install it but i dont know , right now i just want to get it going.
Old Aug 22, 2004 | 11:04 AM
jdhuegel1's Avatar
Glug Glug Glug Burp
My bad. I actually thought you had to remove it with the Haltec.. Oops!
Old Aug 22, 2004 | 02:08 PM
r0gu3's Avatar
Boostless FD
Well, every Haltech aside from the E11 can't control the stock OMP.
Andrew7dg
Aug 6, 2017 01:41 PM
lnlreaper
Sep 27, 2015 09:59 AM
