Why is my car smoking?
Old Aug 19, 2004 | 07:02 AM
trevrev97's Avatar
Car has not been running much the last two years i just bought it last month. i put new plugs in last night it started right up. idle is a little high and it smokes white real bad on and off any help would be great. Oh and i have the holley carb from Racing Beat. If some one could tell me where the mixture screw is if you think that might be the prob thanks a bunch.
Old Aug 19, 2004 | 07:12 AM
Gregs's Avatar
if it smokes your motor is probably shot.... street port it
rebuild it
you will be happy with it then
Old Aug 19, 2004 | 07:24 AM
trevrev97's Avatar
but the car runs good?
Old Aug 19, 2004 | 07:35 AM
Brianhsval's Avatar
I'm old but not slow
White smoke? Water. What does it smell like? If it is waterit is either your intake O- rings, for carbed or your housing seal. If it is the housing seal do a search for Paul Yaw's fix. It worked with mine.
Old Aug 19, 2004 | 08:47 AM
trevrev97's Avatar
White smole stinky hard to tell the smell sorta like a two stroke.
Old Aug 19, 2004 | 08:52 AM
tjgosurf's Avatar
Squeak, Suicide Girls
It probably started smoking at a young age. Patches and gum wont help, shoot it.
Old Aug 19, 2004 | 11:20 AM
trevrev97's Avatar
anyone elses? Rebuild or order a rebuilt? where? oh I have an 81 if it matters. thanks sorry for thr noob Qs.
Old Aug 20, 2004 | 12:59 AM
Brianhsval's Avatar
I am going to assume that U are carbed, therefore if it is water it does not mean re-build. If it is the intake o-rings then it isn't a hard job. As for the bubble gum......hey the **** works!
Old Aug 20, 2004 | 01:57 AM
Kentetsu's Avatar
Take it out and run her up to the redline a few times, then see if she still smokes. After sitting for a long time, some of the seals can get stuck. A good hard running should loosen her up a bit. I'm assuming at this point that the problem is not water leakage, you said it was whitish in color, but smelled like a two cycle engine, so sounds like oil or over-rich.
Might be worth a shot...
Old Aug 20, 2004 | 02:02 AM
jays83gsl's Avatar
1983 GSL, 1987 323 "GX"
Oil is bluish though. Sounds like when my friend blew a head gasket on his Accord?
Old Aug 20, 2004 | 02:55 AM
ch0g0nda's Avatar
Or you know... Just let the car run for a while...
My 7 had been sitting for probably a year and a half (judging when last smog ran up) and all it took was 5 minutes of running for the smoke to clear up.
Change the oil/fuel/air filter(s) and see if anything gets better.
Old Aug 20, 2004 | 06:51 AM
trevrev97's Avatar
Thanks guys i can't really take it for a drive because it is all over the garage, in the prosses of restoring. but i will try all that , thanks abunch i am new to the rotary thing, VW guy for the last 10 years, Any and all help is great.!!!! thanks!!
gtcd
30
Aug 19, 2015 02:44 AM
pzr2
Aug 15, 2015 08:29 PM
WyomingTII
Aug 13, 2015 10:42 AM
