I ran into another problem, does anyone know what it is?
Old Aug 18, 2004 | 06:48 PM
johncaleb's Avatar
I had my car running for about 15-20min. I exahust got really hot, I mean like red hot. There was smoke coming up where the window switches are. So I looked under the car and the catalitic convertor was red and smoking. I new the exahust got hot but I didn't think that hot. Does anyone know what is going on here?
thanks
Old Aug 18, 2004 | 06:53 PM
Your cat might be clogged. Don't you have heat shielding around your cat, or did you take it off?
Old Aug 18, 2004 | 07:01 PM
johncaleb's Avatar
i bought the car like that, i think it is called a manafold, well it smokes when it is running for awhile.
Old Aug 18, 2004 | 07:05 PM
Felgar's Avatar
2 possibilities... The clogged cat as mentioned. Another possibility is a blown apex seal letting raw gas into the line and then it's burning there. I've seen that happen myself. If it runs totally fine them I'd put my money on the cat.
Old Aug 18, 2004 | 07:13 PM
johncaleb's Avatar
it runs fine sort of, i have another prob a couple of threads down. Also there is gas in my oil, i don't know if it was there from beforebut... i changed the oil and haven't checked it since. But if there still is, what is it? what is it from?
thanks
Old Aug 19, 2004 | 02:40 PM
johncaleb's Avatar
Anyone?
Old Aug 20, 2004 | 07:00 AM
Rx7carl's Avatar
Airflow is my life
I cant imagine how gas would get into the oil. Check though to see if its gone now that you changed the oil. Gasoline will thin the oil and make it much less effective as a lubricant.
Microtech
Nov 21, 2015 10:20 AM
alexdimen
20
Oct 23, 2015 01:50 PM
rotary_rx7fc
20
Sep 19, 2015 02:41 PM
The1Sun
Sep 15, 2015 04:45 PM
