Sponsored by: CARiD
not my injectors!
Old Nov 21, 2001 | 05:12 PM
thirteen B's Avatar
not my injectors!
so, i just got my car back with a brand new motor, well, new block and rotor. its an 87 turbo. i was going about 80 mph in 4th gear when i felt a really bad loss of power and my engine was making a clicking noise! what could it be? i have heard that it might be my injectors but, i am not sure. help please
Old Nov 22, 2001 | 02:11 AM
nidfrspeed's Avatar
The only way to tell if the injectors are bad is pull them out and check the ohms. Not sure what the clicking would be though. You could get the error codes and see what it says. If it does that at around 3800 rpm, it's your secondaries that are bad. Describe the clicking noise. Does it sound like pinging from the engine?
Old Nov 22, 2001 | 09:11 AM
thirteen B's Avatar
it kinda sounds like marbles dropping on a sheet of metal, its coming from the engine from what i can tell.
Old Nov 22, 2001 | 10:07 AM
AnthonyNYC's Avatar
Stay tuned...
Your motor is pinging for one reason or another. Since it a new motor make sure and check the following.....
Check the wires and make sure they are hooked up correctly.
Leading one - lower left
Leading two - lower right
Trailing one - upper left
Trailing two - upper right.
I could be wrong there cause im not looking at the engine at the moment but the housings are clearly marked. THe housing facing the front of the car is ONE and the one facing the rear of the car is TWO.
Check the wires first.....
Then check the base timing. Make sure your timing is not off.
Check those things and let me know.
Hope it helps.
Anthony
Old Nov 22, 2001 | 10:09 AM
AnthonyNYC's Avatar
Stay tuned...
One more thing, you mentioned 4th gear, what boost are you running. I had a 2nd gen and if you have full exhaust they are known to 'boost crep' when you hit it in 4th.
Anthony
Old Nov 22, 2001 | 05:55 PM
thirteen B's Avatar
can you explain boost crep? i am not sure what you mean
HalifaxFD
Canadian Forum
126
May 9, 2016 07:06 PM
connerfd3s
Sep 19, 2015 05:58 PM
