quick dumb 13bt question
Old Nov 21, 2001 | 01:07 PM
will the upper and lower ( isnt there an upper and lower ) intake manifold from a 13brew fit on the 13bt if so with what mods if any
T.I.A
Old Nov 21, 2001 | 01:23 PM
zyounker's Avatar
root
You can use the upper intake & TB from an FD... You have to do some port matching & round out 2 of the bolt holes on the FD upper manifold...
Do a search on this. it was just talked about a week ago...
Old Nov 21, 2001 | 01:29 PM
i did a search couldnt come up with anything can you point in the right direction thanks
Old Nov 21, 2001 | 01:44 PM
zyounker's Avatar
root
https://www.rx7club.com/vforums/show...n+upper+intake
https://www.rx7club.com/vforums/images/spacer.gif
Here you go....
Old Nov 21, 2001 | 04:34 PM
RX-7 GT's Avatar
HyperREV.com
hey zyounker. did you do it on a series 4 or 5? i forgot also if its a series 4 are you still using pre-mix? cause i heard the rod from the omp is in the way of the fd manifold or some junk?
Old Nov 22, 2001 | 08:34 PM
zyounker's Avatar
root
You will not be able to use the metering rod with the 3rd gen intake.. I will probably run premix. My friend runs a aviation metering pump that is RPM dependant.. It seems to work well..
-Zach
DerpyToast
14
Nov 23, 2024 05:19 PM
SakeBomb Garage
SakeBomb Garage
May 11, 2020 10:04 AM
SakeBomb Garage
Oct 9, 2015 10:05 PM
