electric problem
Old Nov 21, 2001 | 03:07 AM
wai's Avatar
wai
RX7 club knows about you
electric problem
when my car at idle , the voltage is 12v to 12.7v
when I turn on headlight and step on the brake ,
the voltage will go down to 10.6v ,I don't have any subwoofer and amplifier in my car,and my alternator just replaced 6 months ago, the alternator belt is in good condition and does not loose. so is it normal or not?
Old Nov 21, 2001 | 08:37 AM
tims's Avatar
no, sounds like the voltage regulator inside the alternator is not working correctly. I would have the alternator checked and possibly replaced. I would also check that all the battery cables are in good condition and are connected tightly.
Old Nov 21, 2001 | 10:37 AM
Icemark's Avatar
Alt is failing.. or bad grounds on engine and battery.
Make sure when you put the new alt in your didn't overtighten the belt. The belt too tight will cause the alt to fail as well, by too much pressure on it.
When the car is running on less than 12.6 volts, you are only running on the battery.
The1Sun
Sep 18, 2015 07:13 PM
The1Sun
Sep 15, 2015 04:45 PM
firzen
Sep 15, 2015 12:04 PM
