bov replacement
Old Aug 14, 2004 | 04:58 PM
bludskorge's Avatar
bov replacement
how people are running with just the bov?
how many people still have the stock air by pass valve on. reason for asking when im under boost after a couple of seconds the air bypass valve you can hear it leak air and watch the boost drop off to under 0. also what is the better bov to use any company i have a greddy bov. i tried to replace the spring sounds easy .
well i was ripped off for just the spring. 40 bucks. they had the same spring in home depot for 85 cents. wheres the mark up there. any point is when i got home took everything apart and installed the new spring. it still doesnt work. granted it worked before i replaced the spring but that was leaking boost to. ( 10 pounds all i was making ) after i replaced it the spring wont even push open and sovled some of my boost issues. anyone experience this problem bere?
Old Aug 14, 2004 | 11:04 PM
JONSKI's Avatar
5yr member, joined 2001
What are your mods?
The stock BOV works just fine for applications up to about 14psi.
t-von
Sep 10, 2015 01:56 PM
Enzo1944
Sep 6, 2015 08:57 AM
High_Carb_Diet
Power FC Forum
Sep 5, 2015 09:07 AM
