EGI fuse keeps blowing
Old Aug 12, 2004 | 10:19 PM
buzzer's Avatar
i was driving my car last night and it stalled out on me. the air bag light was flashing 3 times. i came home to check the forum and someone told me to check the EGI fuse. so i did and it was blown. i took out the retractor fuse and put it in its spot and turned the key to on (didnt start it) and it blew about 3 seconds later. does anyone know what could be wrong?
Old Aug 13, 2004 | 02:13 AM
buzzer's Avatar
anyone have any ideas?
Old Aug 13, 2004 | 03:06 AM
clayne's Avatar
PV = nRT
So what do you think would cause a fuse to continually blow? (I'm trying to get you to do some pre-emptive deduction here).
Old Aug 13, 2004 | 09:21 AM
DaleClark's Avatar
RX-7 Bad Ass
You likely have a short to ground somewhere, which is REAL fun to try and find. Have you wired any aftermarket electronics into the car? That's the first place I'd check for problems.
If a power wire touches ground, the fuse will blow.
Dale
Old Aug 13, 2004 | 12:56 PM
buzzer's Avatar
i installed my profec b spec I like 3 days ago and it ran fine for 2 days. i put the power wire in with the cigar lighter fuse and found a bolt with another ground wire already on it so i just shared the profec ground wire with that.
FC3S Timmy
16
Oct 3, 2015 01:08 AM
