Power FC What are your Airtemps using hte powerfc's monitor?
Old Nov 20, 2001 | 06:01 PM
bluesaint's Avatar
Im curious to see what air temps u guys getting from highway and local city driving.
Old Nov 21, 2001 | 05:24 PM
Beast From The East's Avatar
Racing is Life.....
With an m2 med i/c around 39 degs C after bonzai WOT runs, with abient temps being around 65 degs F.
Old Nov 21, 2001 | 07:17 PM
machinehead's Avatar
kortez
Same here, same IC, with the XS TO4E kit, very close to ambient. Temps will creep in the city but on the highway they drop back down.
Old Nov 24, 2001 | 10:13 AM
Dr Wankel's Avatar
Altitude SUCKS!!!
Lately I have been seeing temps of 19-22 deg cruising on the highway. And about 35 deg in town. Most of these temps are at night when it has been dropping down below freezing.
Old Nov 24, 2001 | 05:45 PM
7 eleven's Avatar
When I had a Blitz SMIC I saw 60C at 13 psi once on a high 70s day.
Old Nov 27, 2001 | 11:52 AM
FourtyOunce's Avatar
drove to KDR last night. ambient air temp was about 52degF. air intake temps according to PFC was 20degC, which is about 16degF above ambient. not bad since i was boosting about 13# at WOT several times. also, this cooling if from a custom FMIC i recently designed for less than $600.
Old Nov 27, 2001 | 12:24 PM
Roadracing7's Avatar
I'm getting 28C (82.4F)with ambient about 75F after WOT runs. I'm running ported twins and Apex'i FMIC
Old Nov 30, 2001 | 12:28 AM
Xcessive's Avatar
Air Temp
If anybody is interested, I measured Air Fuel Ratio with a wideband on my dyno @20deg C and 40deg C with a change
of approx 1.5 steps in AFR%. When I was changing from
intown to street raceing the AFR would be lean because the
heatsoak of the manifold. So I moved the airtemp from under
the manifold to the outlet of the intercooler (Front mt. Greddy)
infront of the engine compartment to seperate engine heat.
And now I have a lot faster and accurate, reacting air temp correction for the PFC. My air fuel going into the motor is a lot
more stable so as the computer is not trying to correct so drastically (1.5 AFR% is a lot for 20+deg change). Sorry so long,
just my 2 cents, car runs a lot better.
TO4S @ 24lbs
Xcessive Motorsports
Old Nov 30, 2001 | 04:37 PM
bluesaint's Avatar
thank you guys for all ur inputs.
Roadracing7, I noticed you removed your AC, My AC is broken on my 7 and Im thinking about taking it out. Can you sort of guide me through? Like how long did it take, how hard is it, what needs to be replaced (new belts, part# etc.) thanks.
sukimoto
Rotary Car Performance
Oct 26, 2015 02:37 PM
subeone
Sep 19, 2015 12:07 PM
