Which turbo could i support?
Old Aug 11, 2004 | 12:16 AM
importrx7's Avatar
To Live Is To Die
I was wondering which single turbo/'s my set up could support. I'm running a compettion fuel pump, 1300cc Secondary Injectors, Greddy 2-row FMIC, Greddy Blow-off Valve, AEM Ignition, PWR Radiator, Power FC, Downpipe, Mid-Pipe, Catback, ACT Clutch, RacingBeat Flywheel.
Old Aug 11, 2004 | 05:13 PM
racer1's Avatar
flying apex seal
What kind of turbo do you want? For which application? Street use,drag?
Old Aug 11, 2004 | 07:20 PM
importrx7's Avatar
To Live Is To Die
I want to run a street app.
Old Aug 11, 2004 | 09:25 PM
racer1's Avatar
flying apex seal
I'd go with a GT35/40. But it depends on how many horses you want.
Old Aug 11, 2004 | 09:35 PM
importrx7's Avatar
To Live Is To Die
I don't want to go over 400rwhp, my concerns are im still running stock primary injectors, and i only have a boost gauge. I know i'll need a fuel pressure, and oil pressure gauge, but don't know if i'll need a/f or not.
Old Aug 12, 2004 | 12:12 AM
racer1's Avatar
flying apex seal
For the power you are looking i would definitely go with GT35/40, unless you have the money for an RX6. Your injectors are just fine, you don't need to upgrade your primaries.
About gauges, i already installed boost,water temp,oil press, fuel press,oil temp but unless you install a wideband, the a/f gauge is just a stupid light.
Old Aug 12, 2004 | 12:13 AM
badfish229's Avatar
Kutabare
Holy crap! 345 rwhp isn't that bad for the stock twins. Why are you considering a single?
Old Aug 12, 2004 | 12:34 AM
importrx7's Avatar
To Live Is To Die
The turbos died so thought why not, was kinda thinking of a t04e, nice small single and should a fast spoller
Old Aug 12, 2004 | 12:36 AM
importrx7's Avatar
To Live Is To Die
They were good turbos and shows what good tuning can do. It was tuned by jason @ rx7store.net
Old Aug 12, 2004 | 03:40 AM
1revn3rdgen's Avatar
I think the to4e would be a good turbo for the power you want.There was just an xs engineering turbo kit on ebay and it was the to4e turbo kit.
Old Aug 12, 2004 | 07:50 AM
Broken09's Avatar
I am becoming...
Could go with the 35r with the smaller wheel. If that's all the power you're looking for. There was a thread about it about a week ago I'll try to find it.
-Nic
Old Sep 11, 2004 | 11:20 PM
BoostorLose's Avatar
Bridgeport Anyone??
I agree, the 35/40 would be a good choice. I uprgraded my primaries to 850cc and the secondaries to 1300cc with the appropriate pump and lines and I am supporting a TO4R 1.0 A/R. You'll be fine.
cristoDathird
28
May 30, 2019 08:47 PM
Frisky Arab
13
Aug 18, 2015 05:30 PM
KAL797
Test Area 51
Aug 11, 2015 03:47 PM
