Power FC running lean with mod map
Old Aug 9, 2004 | 10:59 PM
BOTTLEFED's Avatar
Freudian slip
Question running lean with mod map
I just thought maybe someone could give me some ideas on my problem.
I am using the base mod map and you would think it would run nice and rich with my current mods: intake, DP, CB, and gutted cat.
However, I'm running uncomfortably lean according to my Halmeter A/F ratio meter. The ratio seems OK while boosting, so I'm not at a high risk of blowing my new motor. But the thing I don't like is that I run extra hot because of the lean mixture.
So can anyone give me some ideas of what would fix this. I have an SX fpr that I can raise the fuel pressure with. I'm running 28-30psi at idle. Any help would be greatly appriciated.
Old Aug 14, 2004 | 12:45 PM
Slam Pig
what version of the powerFC do you have???
i heard that the 5.07 is much leaner then the 5.08...
could be way off....still learning this thing
Old Aug 14, 2004 | 04:51 PM
cewrx7r1's Avatar
Eye In The Sky
Do you have the commander for it?
If so, why haven't you added more fuel?
Go AFR tune it.
Queppa
Nov 18, 2024 03:47 AM
rotor_veux
46
Jun 12, 2018 10:39 AM
Microtech
Aug 23, 2015 11:04 AM
befarrer
Microtech
Aug 22, 2015 05:52 PM
smikels
Aug 18, 2015 01:26 PM
