different boost settings with the PFC...
Old Nov 20, 2001 | 01:32 AM
JoeD's Avatar
when you get a PFC tuned, does it have different maps for different boost levels?? for example, if its tuned for 12 PSI, and you wanna up it to 14 for the occasional Supra/Corvette whooping, will it run the same fuel/timing map as 12 PSI. does that mean that you will run leaner at 14 PSI than 12 PSI, or is there a separate fuel/timing map for each individual level of boost??
thanks.
Old Nov 20, 2001 | 07:58 AM
Johnny's Avatar
OG
Tune it for the higher of the 2...it will adjust itself if you end up running lower boost.
Old Nov 20, 2001 | 08:43 AM
puma's Avatar
canadian monster
is there a use to buy a boost controller when you have a PFC?
Old Nov 20, 2001 | 09:36 AM
Johnny's Avatar
OG
Was not for me....
I run 10 and 12 all day long.. pretty stable control
Old Nov 20, 2001 | 05:00 PM
RecKleSs's Avatar
Adrenaline
It's not necessary to buy a boost controller for the Power FC. However, it is much easier to use a boost controller than using the Commander. The boost controller can be easily used with the Power FC. I'm using the Blitz SBC i-D boost controller with my Power FC and I think it's so much better now.
Old Nov 20, 2001 | 10:33 PM
JoeD's Avatar
ok, thanx guys.
Old Nov 21, 2001 | 12:45 AM
Dr Wankel's Avatar
Altitude SUCKS!!!
Anyone using the APEXi AVC-R? My friend is using one on his Supra and really likes it. Any experiences with them on a RX-7.
Old Nov 21, 2001 | 07:42 AM
rotaryextreme's Avatar
Veteran: Navy
Re: different boost settings with the PFC...
On the fuel and ignition maps, it's pressure vs rpm. So if you tune for the whole map, it will cover up to 1.4 kg/cm3. You can make it run richer at higher boost using the same map as long as you put higher values into the cells corresponding to the higher boost level. Hope it helps.
Chuck
thanks.
Jun 26, 2016 10:21 AM
sen2two
AEM EMS
Oct 23, 2015 07:51 PM
