Power FC PFC in car, now wont start?
Old Aug 8, 2004 | 03:06 PM
PureMdMa's Avatar
1 of 203 94 White PEP's
Well i put my pfc and commander in the car yesterday and it fired right up the first time then started doing the learning up down rpm thing, did this for bout 30min then quit so I went for a drive up to the store and it did the jumping up and down a few more times. I got home and the idle seemed to even out and was smooth as silk so I thought I was set right? Well I got in the car today and it wont start at all. It turns over fine but doesent start at all? Anyone know what might be the best solution for this other than just going back to the Pettit ECU I had in there? Any input would be most appreciated other than someone just telling me to do a search, I have done that and dont have hours more to spend on it.
Laterz
Jeremy
Old Aug 9, 2004 | 12:10 PM
cewrx7r1's Avatar
Eye In The Sky
Check all maps that affect idle and starting. Primarily the idle control map and idle encrichment map. Compare to others maps if you can.
Call me tonight and I can tell you about what they should be.
(281) 240-3710 Houston CST after 5PM.
Old Aug 16, 2004 | 06:11 PM
luizajeff's Avatar
Did you pop a fuse? Sounds like something that happened in my Honda once, turned over but not start. I checked all the fuses and the ECU was out. I replaced and haven't had trouble since?!
Old Aug 17, 2004 | 10:00 AM
cewrx7r1's Avatar
Eye In The Sky
The dude never reponded back to me. Either he got local help, or discovered he did something stupid and has fixed it.
Kyo
Apr 13, 2019 09:24 AM
torky007
Aug 17, 2015 05:14 PM
Snook
Aug 15, 2015 08:18 AM
blkops
Aug 12, 2015 01:30 PM
