Best Engine to Start With
Old Aug 5, 2004 | 09:23 PM
elwood's Avatar
I currently have a streetported '76 Rotary Pickup 13B, and I've decided to go turbo. Here are my engine options, what are some of the pros/cons:
1. Keep my early 13B 4-port and use FC Turbo rotors. Use a custom IDA-style intake with injectors in the throttlebody & an EFI plenum. (cheapest alternative, I think)
2. Used 13B Cosmo engine & intake. (more expensive)
3. Used FD engine & intake. (most expensive)
I plan to use a cast iron HKS exhaust manifold with external wastegate designed for Turbo II (FC) cars.
Old Aug 6, 2004 | 01:21 PM
bcty's Avatar
Boost This!
13B RE is your best bet
Old Aug 6, 2004 | 10:48 PM
elwood's Avatar
Why? What makes it better? Can I modify the others to achieve the same?
Old Aug 7, 2004 | 12:30 AM
Turbo II FC's Avatar
Total Balance is Key
I believe alot of people like the RE and think its the best bet because of the large port sizes stock. You would have to port the hell out of 13BREW irons to start with the same size ports as you would have with stock RE ports. And then, you can port the RE's to a size you cant on a 13BREW. I believe the RE is the best to start with as well.
Old Aug 7, 2004 | 06:12 PM
T88FD3S's Avatar
1highrevvin7
13b-re or 13b-rew
Sorry for asking such a newbie question, but whats the difference between the 13B-RE and the 13B-REW?
Old Aug 7, 2004 | 08:12 PM
chris_stampe's Avatar
the re came in the cosmo and had larger intake ports. The rew came in FD's and it has large exhaust ports, but smaller intake ports. The best is to use the housings from the rew and the intake plates from an RE. Im just there are other little differences too though.
Old Aug 8, 2004 | 12:45 AM
elwood's Avatar
What about the intake manifolds? I read on the HITMan's site that the B-REWs had a better-flowing intake setup. If true, would this offset the port size differences?
Old Aug 13, 2004 | 05:10 AM
Jon Goodwin's Avatar
The ports on the intake manifold on the RE are larger, and so is the throttlebody. As you have been using the early 13b, the engine mounts for the Re are near enough in the same place, where as the REW mounts are totally different.
John
88 GT-R
Old Aug 14, 2004 | 03:07 AM
BoostedRex's Avatar
NorCal 7's Co-founder
I'll add another vote for the RE option. That is going to be a good place to start and end that project. If I remember correctly the RE not only has larger intake ports, but aren't they equal size as well where as the REW intake ports are two different sizes?
Zach
Old Aug 14, 2004 | 09:14 AM
Thats right mate, as i recall i think they are all 45mm, where the REW is 2x45 and 2x38??
John
GT-R
Old Aug 14, 2004 | 03:41 PM
b005td7's Avatar
13b-re ...
the intake looks good too
Old Oct 10, 2004 | 12:00 PM
Rx7 922's Avatar
Dump A 20b
Kyo
Apr 13, 2019 09:24 AM
Th0m4s
Feb 26, 2019 02:04 AM
befarrer
Aug 14, 2015 04:18 PM
