Front Cover removal
Old Aug 4, 2004 | 08:59 AM
SOIA's Avatar
Take A Look Around
Front Cover removal
I am in the process of putting my S4 components on an S5 block and I am going to change the front covers now, but I've been reading about the torrington bearings causing problems, I can't find any good instructions on front cover swaps and I don't want to mess anything up.
Should I change covers with the engine in the car, or out? I suppose it's a good thing that I couldn't get the e-shaft bolt off, as I had not read about the bearing probs untill now
Old Aug 4, 2004 | 09:20 AM
Aaron Cake's Avatar
Engine, Not Motor
If you're going to pull the engine, then do it out of the car. But if not, it can be done in the car. Just pay attention to the bearings. Easiest eay to hold them in place is to wedge the clutch pedal down (make sure your hydraulics are in good shape). For bolt removal, the only way to go is an impact wrench.
Old Aug 4, 2004 | 09:24 AM
SOIA's Avatar
Take A Look Around
it's already out, mazdatrix, or somewhere I read, said to place the engine verticaly with the flywheel down, is that the best way to go?
Old Aug 4, 2004 | 09:29 AM
Turbonut's Avatar
This is from the Mazdatrix website:
http://www.mazdatrix.com/faq/pulley.htm
Old Aug 4, 2004 | 09:33 AM
YearsOfDecay's Avatar
Locust of the apocalypse
From: Directly above the center of the earth (York, PA)
Yes, make sure that the engine is flywheel down and don/t move it until the job is done. the reason being is that the bearings can slip if you have the engine horizontal and then when you tighten the bolt, you mash the bearings!!!!
FD7KiD
15
Feb 26, 2021 10:12 PM
FD7KiD
Aug 17, 2015 11:50 PM
morataya
Microtech
Aug 17, 2015 01:04 PM
