how big is your fuel pump and what brand?
Old Aug 3, 2004 | 02:01 PM
FD3SR1's Avatar
I was wondering what fuel pumps you guy are runnig with your single turbos, and why your runnig it? the reason im asking is because i would like to use this as a referance for puting my turbo kit together. also what size ex. 255 ect.
Old Aug 3, 2004 | 02:09 PM
spoolin93r1's Avatar
i'm running the nippon desno unit from rx7store.net
not sure of actual flow, but it states over 500hp. i'm running 439rwhp right now and have had no issues
Old Aug 3, 2004 | 03:56 PM
badfish229's Avatar
Kutabare
What are your specifications for your project, FD3SR1?
Old Aug 3, 2004 | 09:30 PM
b005td7's Avatar
walbro 255
it should be the simplest swap for stock pump
Old Aug 3, 2004 | 09:48 PM
shawnk's Avatar
Perpetual Rebuilder
I have heard bad things about the bearing on walbros. I have a cosmo pump pushing fuel to my 720/1680 injectors. It gets me to 16psi boost (which requires about 60 psi fuel pressure) on my t04S with no pressure drop problems. I think this is about 375rwhp range. I have also run the supra TT pump and it delivered well also until it died .
Old Aug 4, 2004 | 12:42 AM
82streetracer's Avatar
8/1 Building/Drive Ratio
aeromotive a700
Old Aug 4, 2004 | 01:12 AM
Brian_93's Avatar
T-88 FD
Wink
Stock Twin Turbo Supra fuel pump , 404rwhp and no problems .
Old Aug 4, 2004 | 05:07 AM
88fc3sw/HX83's Avatar
Dual In-Tank pumps (Apexi BNR33)
Old Aug 4, 2004 | 07:36 AM
rob20rx7's Avatar
Injected with a Poison
aeromotive Tsunami Intank pump with - 8 feed line and a -6 return 405 RWHP @19 PSI with TSO4
Old Aug 4, 2004 | 07:37 AM
rob20rx7's Avatar
352 Tq
Old Aug 4, 2004 | 08:28 AM
jdhuegel1's Avatar
Glug Glug Glug Burp
Dual Walboro 255's with the relay tripped to 12V constant.
Old Aug 4, 2004 | 08:54 AM
zinx's Avatar
_________________________
Aeromotive A1000 with a constant 12V relay as well, but i'm looking into getting the Aeromotive Fuel Pump Controller to control the pump.
Old Aug 4, 2004 | 01:15 PM
FD3SR1's Avatar
HKS to4r
Apex-i power fc
1600cc
850cc
and all the other goodies intercooler ect.
FD3SR1's Avatar
im looking for around 450rwhp +
Old Aug 4, 2004 | 05:49 PM
frode's Avatar
2 x Bosch -984
Old Aug 4, 2004 | 06:04 PM
the denso unit i have has been tested to over 500rwhp and is a direct drop-in. it makes no noise whatsoever and is as reliable as an oem unit. they're around $225 at rx7store.net i do believe
Old Aug 4, 2004 | 06:21 PM
GOTBANNED?'s Avatar
Boost Addict
would a 255walbro be good enough for a 60-1 with 1600 injector running 12 and 18 psi?
Old Aug 5, 2004 | 11:13 PM
jhillyer's Avatar
Aeromotive Eliminator
It's shelf-warming right now, as much of the car as I restore. I'm considering a speed controller.
Old Aug 6, 2004 | 10:14 PM
Not Stock's Avatar
seeking10s
aeromotive a1000, an lines, 850primaries, 1600secondaries, sx regulator. Pt 67gtp,
apex frontmount i/c converted air to water. Start tuning soon. Running 9.7 rotors,
stock ports[trust me] want close to 500rwhp @ 22psi- will post results.
Old Aug 7, 2004 | 11:25 AM
93FD3S's Avatar
Big Snail
Any pointers on how to set this up? Thanks
Old Aug 7, 2004 | 05:05 PM
doridori-rx7's Avatar
Navy MarCom
twin walbro 255's -8 high press line to twin -6 out to mallory FPR -10 return line E6X/ 720-1600 / T70 no dyno but the math says at 80psi I'm getting @455 rwhp
Old Aug 8, 2004 | 02:52 AM
RX7 RAGE's Avatar
Bann3d. I got OWNED!!!
Top Answer: 1
walbro 255 here
Old Aug 8, 2004 | 02:11 PM
Marcel Burkett's Avatar
2 x Bosch ' 044 's. , Aeromotive pumps suck ***.!!!
Old Aug 12, 2004 | 01:11 AM
sub-zero's Avatar
My new Aeromotive Eliminator takes My T04R up tp 25 PSI and I have below 90 % duty on the PFC. The Aeromtoive A 1000 is not near the pump the Eliminator is hence it is more expensive and it is also more quite.
Old Aug 12, 2004 | 10:16 AM
jdhuegel1's Avatar
Glug Glug Glug Burp
Well, for the time being (until I need more fuel) I’m running a “y” in the tank and using the stock feed line. To trip the relay you need to look here: http://www.nopistons.com/forums/inde...3&hl=12v&st=25
The pictures are on page two.
