Wideband/knock logging tool sale.
Old Jul 29, 2004 | 01:38 PM
XSTransAm's Avatar
Ee / Cpe
Thought maybe some of ya might be interested.
http://www.turboxs.com/
Old Jul 29, 2004 | 04:39 PM
DaleClark's Avatar
RX-7 Bad Ass
Damn, that's pretty slick. I've heard of a lot of the Japanese tuners using a knock sensor with headphones while tuning - you can hear the tiniest pings much better, and know when to back off much earlier.
That's a pretty decent price too. Wish they had a better pic of the unit.
Dale
Old Jul 29, 2004 | 10:59 PM
XSTransAm's Avatar
Ee / Cpe
Dale
what kind of pic do you want, ill take it tomorrow... also this unit will be able to directly interface with a gameboy advance so you can use that as your display... pretty slick ****
Old Jul 29, 2004 | 11:27 PM
ejmack1's Avatar
Lawn Ornament
will it interface with the Datalogit ok? I could care less about a gameboy
Old Jul 30, 2004 | 08:25 AM
DaleClark's Avatar
RX-7 Bad Ass
I'd like to see a pic of the unit/display that's not taken apart, like the pic on the webpage . How big is the unit itself?
Since I'm guessing you have one - what do you think of the unit? Have you tried the knock sensor?
Dale
Old Jul 30, 2004 | 08:38 AM
the_glass_man's Avatar
Will u do me a kindness?
Just use a stethoscope! Hmm, well maybe not. Yes more pictures of the unit and dimensions would be nice. How much work involved to get it to work with a datalogit?
Old Jul 30, 2004 | 09:33 AM
DaleClark's Avatar
RX-7 Bad Ass
OK, after a little more digging in TurboXS's web site, I found out some more.
The unit does quite a bit. Not only wideband and knock readings, but can also monitor 2 12v inputs and 2 pulse inputs. For example, you can tap into a MAP sensor and log it, RPM, injector pulsewidth, etc. That's mighty handy!
Supposedly you can or will be able in the future to hook a Gameboy Advance to it to read data, log, etc. That's just slick. The tuner box is just a serial device - you run a terminal emulator to read it, so ANYTHING that's a terminal emulator will work, even one on a Palm PDA or something. Or you can drag an old dumb terminal in the car .
Here's a copy of the manual for the unit -
http://www.turboxs.com/_images/Tuner...Manual_1v1.pdf
Attached is a pic of the unit with a Gameboy Advance sitting on top. Decent looking unit.
This is one slick device!
Dale
Attached Thumbnails Wideband/knock logging tool sale.-txs_tunerweb.jpg
Old Jul 30, 2004 | 09:41 AM
XSTransAm's Avatar
Ee / Cpe
it can output a 0-5v signal for use with engine management (datalogit)
the unit is 4.5" X 6 1/4" and 1 1/4" deep
Old Jul 30, 2004 | 09:44 AM
XSTransAm's Avatar
Ee / Cpe
I have yet to try the knock sensor on my car since its not running atm... but it works great on the wrx's, The wideband is awesome though. We bought a Motech for testing and ours has a higher resolution than it
Old Jul 30, 2004 | 09:47 AM
jpandes's Avatar
I wonder how much more accurate the Bosch Knock sensor is compared to the OEM Mazda knock Sensor, if any.
Old Jul 30, 2004 | 09:58 AM
DaleClark's Avatar
RX-7 Bad Ass
I know the Bosch sensor is what J&S use for their Safeguard.
The TXS tuner box also lets you tune in the knock sensor - you can free-rev the engine, and dial out any noise so it only hears knock. Being able to actually listen to knock with headphones is a REAL big advantage, too.
I think a knock sensor is pretty much a knock sensor, but the black box that interprets what the mic outputs is the key.
Dale
Old Jul 30, 2004 | 09:59 AM
Nice, not sure how useful the gameboy feature since the screen is so small and the resolution is low. Nice feature none the less. I smell group buy!
Old Jul 30, 2004 | 03:56 PM
XSTransAm's Avatar
Ee / Cpe
some better pics
Old Aug 4, 2004 | 09:29 AM
XSTransAm's Avatar
Ee / Cpe
new information about the DTEC (gameboy interface) is up on the web now.
http://www.turboxs.com/Dtec/dtec.shtml
what do you guys think about the gameboy thing?
Old Aug 4, 2004 | 11:02 AM
RacerXtreme7's Avatar
NASA geek
Talking
Off topic:
{QUOTE:} Aim conversation with my girlfriend
Dancerxxxx: i accepted a long time ago that if the situation ever arose where you would have to choose between myself and your car, you'd pick the car
Dancerxxxx: ...sometimes i wish i had a rotary engine so you'd love ME that much... {QUOTE}
LMAO!!! sounds ohhh too familiar
Old Aug 18, 2004 | 03:05 PM
TKE's Avatar
TKE
im a little confused, this unit comes with a wideband o2 sensor for around $600?
Old Aug 19, 2004 | 08:30 AM
XSTransAm's Avatar
Ee / Cpe
it comes with a bosche wideband, and a knock sensor for 549 shipped.
Old Aug 22, 2004 | 07:31 PM
10sec rx7's Avatar
i use one of these units on out dyno dynamics dyno's here in Australia, they work a treat, very accurate, very fast, the Knock sensor works a treat, i use it on just about every car that i tune,
we use the 0-5v output to send the afr signals straight to the dyno and all logging is done on there, there was a problem with the output being to slow but turbo xs fixed this straight away for us.
i highly reccomend this unit to anyone!
Dale
Old Aug 23, 2004 | 07:44 AM
John at J&S's Avatar
Here's another company making a low cost ($40) interface for the gameboy:
www.educatingmario.com
At the moment, it doesn't data log, but the designer is working on it.
I'm using it as a low cost storage scope: http://www.jandssafeguard.com/educatingmario.html
Old Aug 23, 2004 | 12:28 PM
t-von's Avatar
Rotor Head Extreme
Dale
So if one was to buy a Microtech ecu for a 20b(Ltx-12s), this little unit could be used in place of the A/F set-up Microtech provides?
Old Aug 23, 2004 | 05:36 PM
10sec rx7's Avatar
i have never tryed logging this unit to the microtech, i might try it when i get my car up and running again,
dale
Logan Reinisch
44
Sep 17, 2018 12:20 PM
