was wondering
Old Jul 29, 2004 | 12:08 PM
crista lynn's Avatar
was wondering
hey, new chick here.
is it possible to buy 2 small 4 lb turbos and somehow attach them to my mazda trix true dual exaust, one tiny turbo for each rotor? im talking like motor cycle turbos, just to get a little more umph.
crista lynn
Old Jul 29, 2004 | 12:13 PM
YearsOfDecay's Avatar
Locust of the apocalypse
From: Directly above the center of the earth (York, PA)
Yes, its possible, but MAN, you are talking about a LOT of work in fabrication and a lot of money.
It would be far cheaper and easier to do a tII conversion.
Old Jul 29, 2004 | 12:17 PM
Travelintrevor's Avatar
B.G.O.B.G.A.I.
what year and model 7 do you own...and I can't see it being any cheaper for two small turbos then for a regular one..Racing Beat used three turbos on the three rotor Boneville car so it is possible.
Old Jul 29, 2004 | 12:24 PM
Dokta's Avatar
You could fabricate a system like that, but it is definately a lot of work. I bet it would be hella fun trying to make it work though.
Old Jul 29, 2004 | 12:53 PM
i wouldnt mind buying a separate r/b header, havind it cut and having the turbos fabricated to fit it. i just think itd beel cool and uniqure to have 2 tiny turbos, one for each rotor, un collectected, totally separated, for that little bit of power.
what i need to know, is what tiny turbos would i need to get. with that, i can fabricate anything
Old Jul 29, 2004 | 02:01 PM
Dokta's Avatar
http://www.jimwolftechnology.com/wol...TCATOLOGUE.pdf
You can check out garretts catologue, they have turbine vs airflow, and pressure ratio vs airflow charts. It looks like for this application, you would need a couple of gt12/gt15 turbos. They go for 500-800 a piece. Unless you can find some used.
Either way, that would be one sick twin turbo setup.
Old Jul 29, 2004 | 02:28 PM
thanks, im printing it out now. i jus tthink itd be cool to have 2 small turbos all by them selves. its like 2 rotors running on their own. i already have one haltech wide band o2 meter per rotor, and i already have dual capibilities for readouts. so why not go for a small boost on top of all that?
thanks a mil
Old Jul 29, 2004 | 02:42 PM
Aaron Cake's Avatar
Engine, Not Motor
Might as well just use a single turbo. If you're worried about turbo lag, don't worry about it. With the high compression engine, it's nonexistant.
http://www.aaroncake.net/rx-7/naturbo.htm
ArmAnirx7
West RX-7 Forum
35
Mar 8, 2021 12:54 AM
sukimoto
Rotary Car Performance
Oct 26, 2015 02:37 PM
TeamRuffRacing
Sep 30, 2015 08:13 PM
