vacuum hose/emissions question
Old Jul 29, 2004 | 12:30 AM
razorback's Avatar
You've Been Punk'd
so i have all emissions (including the bac), ac, ps, and abs removed from my car and i have an s5 in an s4. how much vacuum hoses of each size do i need?
Old Jul 29, 2004 | 01:55 AM
razorback's Avatar
You've Been Punk'd
bump. damn these get down fast.
Old Aug 10, 2004 | 02:09 AM
razorback's Avatar
You've Been Punk'd
bump
Old Aug 10, 2004 | 02:29 AM
ilike2eatricers's Avatar
I R SAD PANDA W/O BAW
http://fc3spro.com/TECH/PROBLEMS/EM/vhoses.htm
Just buy the hose techniques kit. It's been on clearance at mazdaformance for $49. http://www.mazdaformance.com/Merchan...egory_Code=470
you get way more than you need so you have some for emergency situations.
Old Aug 10, 2004 | 02:33 AM
razorback's Avatar
You've Been Punk'd
well i dont have emissions. like anything. so i dont want to spend too much
Old Aug 10, 2004 | 05:04 AM
NZConvertible's Avatar
I'm a boost creep...
All you should have left is the FPR line, fuel injector bleeds, oil nozzle bleeds and wastegate hose. A measuring tape is your friend...
Old Aug 10, 2004 | 05:55 AM
razorback's Avatar
You've Been Punk'd
fpr is fuel pressure relief? and im running premix so no more oil injectors
Old Aug 10, 2004 | 06:20 AM
KNONFS's Avatar
B O R I C U A
I purchased about 25FT, and still have like 8 FT left, however most of it was used for the boost gauge!
Old Aug 10, 2004 | 08:06 AM
YearsOfDecay's Avatar
Locust of the apocalypse
From: Directly above the center of the earth (York, PA)
Yeah, once you get rid of all that crap, you don't need much.. I think I got 1 foot of 10mm for the brake booster hookup, 6 feet of 8mm for the larger lines and Fifteen feet of 6mm and I used it all... but most of the 6mm went to the boost controller. WHen you get rid of the emissions crap, you can also buy a lot less vac line!
Old Aug 11, 2004 | 01:51 AM
Fuel pressure regulator. It's mounted on the secondary fuel rail, and it's vac line should be connected to the angled nipple on the inside of the LIM.
_Tones_
May 25, 2021 05:37 AM
ZacMan
Sep 19, 2015 09:20 PM
Nosferatu
Sep 5, 2015 02:13 PM
Frisky Arab
Sep 4, 2015 06:17 PM
