Rear brake rotor question ...
Old Jul 28, 2004 | 04:10 PM
The_Dude's Avatar
TT 1st gen ? We'll see !
Unhappy Rear brake rotor question ...
Hey all ... yeah , I'm back ! :P lol ...
I had this question ... I changed my pads in the back yesterday and .. well .. the oddest thing ... once I put the caliper over the pads, the rotor is , well, crooked :S it doesn't fit snuggly anymore, and I actually have to push on the wheel to get the bolts in !!
What could be wrong ?
Thanks !
Eric.
http://mikehunt2.no-ip.org/my-rx7
Old Jul 28, 2004 | 04:35 PM
The_Dude's Avatar
*bump* lol .. common people .. I really wanna get this fixed tonight .. NE body have a clue !? :S
Old Jul 28, 2004 | 05:32 PM
Rx Loco's Avatar
Newbie
Hey I had a problem with mine also and it was the base...it was hit somehow to the inside...I got it back in place with a 2lb hammer and a straigh edge...tap on it soft and take it back where it belongs slowly...i hope this helps you
Dan
Old Jul 28, 2004 | 05:40 PM
Dom's Avatar
Dom
callin' tokyo
I had a problem with my new front pads not going on. It turned out to be the mounting plate for the caliper being bent. I crowbar'd it back to 'oem specs'
Old Jul 28, 2004 | 05:42 PM
The_Dude's Avatar
Hmm ok .. I was wondering if I should use ... "OEM techniques" or not ... the only thing .. mine looks all normal :S brb I'll go take pics :P
Old Jul 28, 2004 | 05:58 PM
The_Dude's Avatar
here http://mikehunt2.no-ip.org/fix_rx7
go take a look ... tell me what needs to be done mouhaha lol
Old Jul 28, 2004 | 06:00 PM
The_Dude's Avatar
What do I have to "bang" on ??? or nudge with crowbar ?
Old Jul 28, 2004 | 06:09 PM
Dom's Avatar
Dom
callin' tokyo
Is that the caliper mounting bracket almost touching the brake rotor?
Seems that should be centered.
How does it compare with the other side?
Old Jul 28, 2004 | 06:15 PM
The_Dude's Avatar
that's what it looks like when I center the rotor . When I put in the pads and close the caliper, it obviously pushes against the rotor, thus putting the rotor crooked .. then to put the wheel on, I gotta force it in :S
I would have to check the other side but ... I'm pretty sure it doesn't look like that ..
Old Jul 28, 2004 | 06:40 PM
Dom's Avatar
Dom
callin' tokyo
If your brake rotor can be moved then you have a bigger problem.
How's the wear on that tire? Is the wear feathered?
Could you hear a wooing sound when you drove?
Old Jul 28, 2004 | 06:45 PM
The_Dude's Avatar
the rotor can move perfectly .. heck, If I had a little bit bigger gap I could remove it lol the wear is right down the middle .. I guess this hasn't been going on for that long .. 2 months back I changed the tires and had no problem putting it back on ...
Old Jul 28, 2004 | 07:35 PM
The_Dude's Avatar
You can't move the rotor when the wheel is on though loll :P
the bolts hold it in :P
Old Jul 28, 2004 | 09:49 PM
Rx7carl's Avatar
Airflow is my life
Thanks !
Eric.
Well Im gonna assume you retracted the caliper correctly by turning it back in. That means the pads will loose till you apply the brakes a couple of times to push out the calipers and seat the pads. Also from what I gather , you dont have the 2 rotor retaining screws installed (little holes in the hub). Also rust builds around the rotor where the wheel mounts (center hub), making it difficult sometimes to get the wheel on all the way by hand. All that seems to be where you are. So clean the hub, bolt on the wheels, pump the brakes to seat the pads and you should be ok.
Old Jul 28, 2004 | 10:06 PM
The_Dude's Avatar
nah actually .. that's not where the problem lies ... I did the whole brake change ok ... I even got the 15$ tool to compress the calipers (best thing ever invented lol ) ...
The problem lies where that steel plate that the caliper bolts onto .. it's well, crooked ! lol
I pried it back juste a bit with a hammer, but I'll need more then that .. NE body got tips ?? check the pics out carl you'll see what I meen by crooked ...
thanks
Old Jul 29, 2004 | 02:49 PM
Dom's Avatar
Dom
callin' tokyo
If you bolt on the spare, will that give you a leverage point for a crow bar?
You did check the other side right?
Old Jul 29, 2004 | 09:12 PM
GavinJuice's Avatar
Leave A Message
From what i can see from the picture, and what your explaining, i think thats your caliper mounting bracket. Its kinda hard to see from the picture. Take one straight on from the rotor so we can see better. If thats what it is, your going to have to buy the WHOLE caliper as they don't sell them individually from the caliper.
Marty RE
Aug 17, 2015 09:36 AM
Marty RE
Aug 13, 2015 11:19 AM
