serious idle problme pising me off
Old Jul 27, 2004 | 03:08 PM
double barrel's Avatar
removed 5 and 6 acuators and my car idles at 1500 and it shuts off unless i keep on the gas, no vacum leaks i am positive, someone help me i have wrote this before but didnt get much help
Old Jul 27, 2004 | 03:16 PM
DEZERTE's Avatar
777** The Anti-rice
did you remove the coldstart from your TB or anything like that?
How did u seal up the actuator holes? Vac leaks can be in bad gaskets to...did you use new gaskets on your intake when you took everything off? Bac gasket? Did you remove the ACV and make sure you sealed it up good? Basically, you have to do a good job when blocking things off, theres a lot od diff places for vac leak, My car dies to unless i hold on the gas, but i also removed a bunch of **** from the TB.
gxl90rx7
Haltech Forum
Jun 30, 2017 11:30 PM
The1Sun
Sep 18, 2015 07:13 PM
The1Sun
Sep 15, 2015 04:45 PM
RotaryBobby
Sep 10, 2015 01:33 PM
