1990 turbo engine in a 1987 body
Old Jul 27, 2004 | 12:29 PM
Dillonc123's Avatar
Hey. I was wondering if you can bolt a 1990 turbo engine in to a 1987 body. And what other parts might i need. The engine came with the harness and transmission. any thing will help thanks
Old Jul 27, 2004 | 12:32 PM
Aesop Rock's Avatar
Will Work For Apex Seals
do a search because there a few people who have done this, the counter weights are different, you'll need the 90 wiring harness, and 90 ecu, and i think you'll be set
Old Jul 27, 2004 | 12:53 PM
Dillonc123's Avatar
Thanks a lot.
Old Jul 27, 2004 | 01:06 PM
Aaron Cake's Avatar
Engine, Not Motor
Sure it can be done, but the wiring changes are basically a nightmare. Best to stick with your "series" of engine. Swapping S4/S5 and vice versa is a major hassle.
Now, you could put in the S5 block and run the S4 electronics, but that sort of defeats the purpose of the swap...
Old Jul 27, 2004 | 01:36 PM
Dillonc123's Avatar
what will i have to rewire?
Old Jul 27, 2004 | 01:37 PM
Aaron Cake's Avatar
Engine, Not Motor
Everything.
Old Jul 27, 2004 | 02:30 PM
a7r's Avatar
a7r
Basically stick with your series engine unless you've got a standalone. If you've got a standalone and you're sticking with the stock turbo I'd highly suggest swapping up to an S5 turbo and engine, this is my setup and I love it.
-David Guy
88TII
Old Jul 27, 2004 | 02:33 PM
Dillonc123's Avatar
thanks
Old Jul 27, 2004 | 05:19 PM
DEZERTE's Avatar
777** The Anti-rice
Originally Posted by Aaron Cake
Everything.
cam_7779
Aug 18, 2015 07:48 AM
pzr2
Aug 15, 2015 08:29 PM
KAL797
Test Area 51
Aug 11, 2015 03:47 PM
