91 n/a Perfect idle but stalls with accell..
Old Jul 26, 2004 | 09:29 PM
Dlbgirl's Avatar
OK, took an engine out of an S5 vert and put it into a 91 n/a. The engine ran fine when pulled, sat 6 months, then installed into the 91 Coupe. Both have AT. Anyway, the car idles perfectly and revs freely, but runs like crap. Seems like OMP symptoms but no codes. Cats are new, I swapped the complete LIM and UIM (TPS,BAC,etc) with injectors. When I put the car into R or D, it acts as though the AFM is unplugged, and I swapped that out as well with no change. Compression was good when engine was removed, and I pulled the plugs today and listened for the balanced "pffft pfft pffft", everything sounded normal. Anyone have any ideas before I end up swapping EVERYTHING?
Old Jul 26, 2004 | 09:32 PM
SonicRaT's Avatar
Super Raterhater
When do you check your error codes? And does it run fine up to a certain point, then start to cut out?
Old Jul 26, 2004 | 09:52 PM
Dlbgirl's Avatar
Well, I checked codes (even though there was no check engine light) after the car ran like crap. It will go into drive and reverse and drive with no problem, just when I apply gas. If I ease into it from idle, it will accelerate choppily, and flooring it from idle with just make it cut out.
Old Jul 27, 2004 | 02:48 PM
Dlbgirl's Avatar
I guess I'll go swap the OMP today...still hoping to hear from someone who knows these symptoms
Old Jul 27, 2004 | 06:03 PM
cwsttu's Avatar
1.3L is not that small
you should check the AFM.. thats exactly what mine did and blew my mind until i found out the AFM i had bought from o'reily's was BAD... got one off the forum and havent had a single problem with my car since
christopher
Old Jul 27, 2004 | 06:51 PM
Dlbgirl's Avatar
I had swapped the AFM, but I'll swap in another. I swapped OMPs and it ran fine (for the first time since the swap) for 1/8 mile and then started to crap out again(seeming as though the OMP is bogging down-I don't know)...now I swapped oil injectors and I probably should swap oil inj. lines, but I'll see if the injectors make a difference first.
Old Jul 31, 2004 | 08:59 PM
Dlbgirl's Avatar
Swapped oil injectors and ECU. Still the same problems. The car seems to act OK until it warms up. And then it will just crap out with gas. I don't understand it...I have swapped out most of the motor it seems. Acts like it is a fuel or air issue, but the car ran fine until the front rotor gave out and the engine I put in ran fine before I pulled it out of a vert. Still no codes...
Old Aug 1, 2004 | 08:04 PM
Dlbgirl's Avatar
ttt
Old Aug 2, 2004 | 04:41 AM
Dlbgirl's Avatar
I am about to part this damn car out...
Old Aug 2, 2004 | 11:48 AM
Peruvianrx7's Avatar
replace ur fuel pressure regulator an dull eb fine just try this oen thing if it doesnt work ill buy ur front bumper =)
barkz
Power FC Forum
37
Nov 21, 2020 09:34 AM
mulcryant
Sep 9, 2015 05:24 PM
Steven_McKinley
Sep 5, 2015 10:48 AM
