Carter fuel pump installed - pics
Old Jul 26, 2004 | 08:13 PM
cdrad51's Avatar
Lorem ipsum dolor sit ame
Went for this position rather gettting it placed on the rail.
Old Jul 26, 2004 | 09:56 PM
rhinor61's Avatar
Those plastic ty-raps look a little tight, almost pinching the fuel line.
Also why did you remove the metal tray the old fuel pump was mounted to? I mounted my fuel filter in the orginal spot so it can sit level.
You are going to find the pump is noisy, I added some rubber padding between mounting plate and the car body to help some.
John
Old Jul 26, 2004 | 10:05 PM
RotaryRyan's Avatar
DSM
Looks good! Is it sitting upright? Its hard to tell. I have a carter the same size as yours. I had a time installing it.
Old Jul 26, 2004 | 10:35 PM
Jon_Valjean's Avatar
Looks good, but you definately need some rubber mounts, it'll drive you crazy otherwise.
Old Jul 26, 2004 | 10:42 PM
Misthael's Avatar
part number????
Old Jul 26, 2004 | 11:07 PM
cdrad51's Avatar
John
Good point. I might re-install it. Lines are not being pinched, it just looks like it.
Old Jul 26, 2004 | 11:09 PM
cdrad51's Avatar
It is upright. The first photo shows it a little better than the 2nd.
Old Jul 26, 2004 | 11:11 PM
cdrad51's Avatar
Ha! it's not that loud. I can only hear it at idle. Otherwise, even with the RB muffler, the engine is louder than it. That's without taking into account the stereo
Old Jul 26, 2004 | 11:19 PM
RotaryRyan's Avatar
DSM
Man i have the 16 psi carter pump and its pretty loud. People are always like"whats wrong with your car"
Old Jul 26, 2004 | 11:25 PM
cdrad51's Avatar
Originally Posted by Misthael
part number????
Do a search n0000b!!!!
j/k
Here's the link
http://store.summitracing.com/partde...94&N=120307759
You'll need a pressure regulator or the 8 psi will kill your carb
http://store.summitracing.com/partde...N=120%20300725
some recommend a gauge as well. Up to you.
Old Jul 26, 2004 | 11:27 PM
cdrad51's Avatar
Well I don't know what you got a 16 psi pump for, but my 8 psi one is not too loud
Queppa
Nov 18, 2024 03:47 AM
