High End Power Loss
Old Jul 26, 2004 | 03:48 PM
extreme_rotary's Avatar
High End Power Loss
I have a '87 NA, and i am experiencing high end power loss. When the motor is cold, it runs great, but once it warms up, it looses power past 3800 rpm and sometimes studders there before continuing up. My Air/Fuel Gauge shows that it hits 3800rpm, and goes so lean, that it doesn't even display any lights. I removed my airpump and ACV before i used this motor, would that have any effect? I'm thinking that my secondary ports aren't working? any ideas would be appriciated. thanks,
~Rob~
Old Jul 26, 2004 | 03:52 PM
1987RX7guy's Avatar
Eat Rice Don't Drive it.
IIRC the stock o2 sensor only works during cruising. Your problem seems to be non-functional secondary injectors or a short in their harness. You might want to see if they are good and take a look at their harness plugs and wires for bare wire(s).
Santiago
EDIT** could also be what Aaron stated I misread your post and thought you had a complete power loss.
Old Jul 26, 2004 | 03:55 PM
Aaron Cake's Avatar
Engine, Not Motor
Standard 3800 RPM hesitation (search, check archive).
Make sure your 5th and 6th ports are working (search).
Old Jul 26, 2004 | 04:33 PM
WAYNE88N/A's Avatar
Santiago- the stock O2 sensor "works" all the time, as long as it's hot, just isn't very accurate for tuning purposes...But if you're running lean, it'll let you know...
Old Jul 26, 2004 | 04:35 PM
1987RX7guy's Avatar
Perhaps what I am thinking of is the ECUs usage of the signal?
Old Jul 26, 2004 | 04:37 PM
is there any way to check the seconday port operation without driving down the road with someone in the engine compartment and the hood up?
Old Jul 26, 2004 | 04:44 PM
1987RX7guy's Avatar
We normally recommend applying grease to the rods on the actuators and going for a *spirited* drive. Actuation of the pistons will smear the grease around and make it easy to spot.
Santiago
Queppa
Nov 18, 2024 03:47 AM
Th0m4s
Feb 26, 2019 02:04 AM
C. Ludwig
Jan 30, 2019 06:31 AM
LunchboxSA22
37
Oct 26, 2015 10:53 AM
