Fried part of ECU. Bad idle question too.
Old Jul 26, 2004 | 03:27 PM
The Spyder's Avatar
Never give up!
When I was working on my car- the BAC connector eventualy fell apart and the wires came undone.
Now I am not sure but am almost positive that the lines touched and probably toasted the little resister in the ECU that conrols this.
I already replaced the connector, but it wont work now. Nothing I do can change the bac adjustment.
Only thing I did notice is that when I have my stereo/amps on- the idle levels out at 1k perfectly.
Ive never had a better idle.
I bought the car and it started and Idled at 1k.
I remove the coolant TB lines- now I have a 1.3k+ idle that jumps all over the place. .
Im about ready to replace the damn things to how they were.
After the car warms up- I either get a 600 idle, or a 1k, some times a 1.5-.7 idle.
I replaced the TPS, used a DMM to set it to 1ohm after letting the car warm up.
Im kinda lost to what else I can do.
Old Jul 26, 2004 | 06:34 PM
The Spyder's Avatar
Never give up!
I had a tear in my newer TID couplers weak rubber- got a much nicer thicker coupler.
Idles still bouncing everywhere and being completly random.
Old Jul 27, 2004 | 02:19 AM
The Spyder's Avatar
Never give up!
Did I really toast that part of the ecu?
COmmon guys I cant answer my own questions most the time.....
Old Jul 27, 2004 | 02:22 AM
ilike2eatricers's Avatar
I R SAD PANDA W/O BAW
Have you tried pulling your ECU and opening it up to see/smell for any burnt spots? Check resistance/voltages at BAC connection.
Old Jul 27, 2004 | 02:35 AM
The Spyder's Avatar
Never give up!
Any specific voltage/ resistance I should check for- I have a DMM here to use.
Old Jul 27, 2004 | 02:58 AM
Check the fuel and emissions section for your year in the FSM http://www.cochran-racing.com/FSM/index.html
Old Jul 27, 2004 | 03:13 AM
The Spyder's Avatar
Never give up!
Will do. Thanks!
Old Jul 27, 2004 | 03:15 AM
J-Rat's Avatar
Alcohol Fueled!
Did you jumper the ISC?
Old Jul 27, 2004 | 03:22 AM
I was kinda under the assumption that you got a CEL. Did you?
Old Jul 27, 2004 | 03:35 AM
The Spyder's Avatar
Never give up!
Yes.
smikels
Rtek Forum
May 12, 2016 12:34 AM
pzr2
Aug 15, 2015 08:29 PM
