Power FC just installed PFC, now car won't idle
Old Jul 26, 2004 | 12:25 AM
buzzer's Avatar
i just installed my Apexi power fc and cut the 4 wires that are in the diagram. when i try to start the car, it fires up and starts for just a second then dies. does anyone have any ideas what could be wrong?
Old Jul 26, 2004 | 12:32 AM
Fatman0203's Avatar
I dont have a PFC but I have a similair problem. Does it idle when hot?
Also Ive heard the PFC takes some time to adjust everything to your car.
Old Jul 26, 2004 | 12:48 AM
just keep turning it on and try to make it not stall..... it takes some time for it to learn to our car...
Old Jul 26, 2004 | 11:08 AM
ech's Avatar
ech
Make sure you cut the right wires - make sure that when you looked at your harness you are looking at the same side of the plug as the diagram. That is, make sure you weren't looking at the harness-side plug to determine which wires to cut if the diagram was showing the pfc-side - or vice versa.
If your idle just bounces and/or revs then you just need to let it run for some time at idle (like 10 mins) - even after that it might take sime time to sort out. Ilde may bounce at stoplights on hot days for awhile, but it should work out fine. It took a couple of months for these issues to go away completeley when I replaced my pfc with a new one.
that said - stalling out isn't normal - fist think - check for correct wires - then start looking at other things that you may have touched/disturbed. Loose connections, leaks, etc.
Old Jul 26, 2004 | 11:18 AM
buzzer's Avatar
the car was running perfectly before i installed it. and while it is started for that one second the commander is getting all the readings
Old Jul 26, 2004 | 11:49 AM
Str8Down's Avatar
Avoid Fuego Racing
I did a little write up on how to set your idle with your PFC, so that it will idle perfectly. Here is a link.
https://www.rx7club.com/power-fc-forum-47/c-sensor-issue-assistance-please-330754/
alphawolff
Nov 17, 2015 05:57 PM
sYnth.
Aug 17, 2015 07:28 PM
gabescanlon
Interior / Exterior / Audio
Aug 11, 2015 05:59 PM
