what else do i need with the t78
Old Jul 24, 2004 | 04:50 PM
mazda/feed's Avatar
Thumbs up what else do i need with the t78
im going to buy the turbo by its self and was wondering what else would i have to get sooner or later im just not sure of all the things that i have to get so can soe one please help and give me a run down of wat im going to need with the kit
Old Jul 24, 2004 | 08:31 PM
1revn3rdgen's Avatar
You mean the t78 turbo kit or just the t78 turbo?
If just the t78 turbo you have to get a manifold,wastegate,oil lines,gaskets,and custom make a downpipe.After you have all that your going to have to upgrade your fuel system like injectors, fuel rail, fpr, fuel pump, and an engine managment system like a power fc,haltech,etc... Going single turbo isn't too cheap to do.
Old Jul 24, 2004 | 08:47 PM
apneablue's Avatar
Ok, you say you are "...going to buy the turbo by it self..." then you say "give me a run down of wat im going to need with the kit" So what are you getting...the turbine only or the entire kit?
If you are getting the turbine only you will need...
Manifold
DP
FPR
Ugraded fuelpump and inectors (also will need upgraded fuel rails)
3bar map sensor if you plan or running more than 17psi of boost.
Miscelaneouse oil and fuel lines.
I don't see an upgraded intercooler which you really need if you go single.
I just got done doing having www.GothamRacing.com do a single install and I provided the entire gt35/40 kit and still there are a bunch of miscellaneout things I didn't even think of. If I were you I would just buy the kit and save yourself the headache.
Old Jul 28, 2004 | 10:24 PM
fd3virgin's Avatar
i will sell you my whole kit. i want something else. i am in md also. kvn
Snoopy FD
Dec 8, 2015 01:45 PM
Snoopy FD
Aug 19, 2015 03:40 AM
zayrx7
Jun 21, 2002 01:37 PM
