engine is now aparts...completely (pics)
Old Jul 18, 2004 | 01:51 PM
well i had fun gettin the front pulley off (broke my damn good rachet) but its completely arpat...soon to be cleaned
can the housing and rotors be sand blasted??? will it hurt anything???
heres pics
Old Jul 18, 2004 | 02:57 PM
if its a mastercraft or craftsman ratchet.....take it back and they will replace it or fix it up nice and purrdy
Old Jul 18, 2004 | 07:27 PM
Rx7carl's Avatar
Airflow is my life
DONOT sandblast them. Thats way too agressive. Glassbead or baking soda would be ok. But getting it out of all the nooks and crannies will be tough. Look in the tech and performance section. Theres a great thread on this subject there. Some guys are using oven cleaner, among other things.
Old Jul 18, 2004 | 09:42 PM
thanks carl for the tip...cuz i was sure gona take em into the shop tomorrow and sand blast em.
but i got a better idea...we have a aussie tank (its some kind of Bacterial liquid) that eats greese. so i should clean it up pretty good.
im not able to do the 12a efi like i want because my engine in the car is have compression problems...so i think im gona set this one up stock basically but with blow through turbo and street port.
P.S. carl ill be gettin with you soon about a boost prep nikki.
and it was a craftsman...and i will take it back
thanks
Brad
Old Jul 19, 2004 | 12:45 PM
Jeff20B's Avatar
Lapping = Fapping
Oven cleaner is bad to use.
Old Jul 19, 2004 | 01:02 PM
Blake's Avatar
Bead blasting is definitely the way to go, in my experience. Just make sure to clean all the nooks and crannies with high pressure air, to blow out the glass beads. Obviously, you don't want little beads of glass rolling around inside your engine after you put it back together!
Old Jul 19, 2004 | 01:16 PM
Hades12's Avatar
Burning Oil-Grinding 3rd
I have used sand to clean junk housing. It makes purdy sparks when you hit the inside.
David Hayes
13
Sep 5, 2022 12:45 PM
mazdaverx713b
48
Apr 21, 2016 06:45 AM
82streetracer
Aug 23, 2015 09:28 AM
BLK 93
Aug 19, 2015 03:47 AM
