Dave Lemon re: Renesis Rotors in 13B
Old Jul 12, 2004 | 02:57 PM
xero's Avatar
I e-mailed Mazdatrix and he sent me a couple responses he made a couple months back, he said someone had posted them on a couple sites, but I couldn't find them searching, so this [may] be a repeat.
We are using RX-8 rotors in one of our SCCA E/Production "street port" 86-91 13B non-turbo engines.
We do no mods to the rotors (except installing the racing rotor bearing). We are using RX-8 racing ceramic apex seals (the OEM RX-8 steel seals
warped too much having to cross the exhaust port). (There IS enough metal to cut the apex seal groove for either 86-91 2mm seals or earlier 3mm seals -- we are looking into making that service available, but are not ready yet)
The rotors are run "backwards" (front in rear, rear in front) so the angle cut on the side of the rotor gives more intake opening timing (RX-8 uses the
cuts for the side exhaust ports). Do not use the "oil scraper ring" outside the second oil control ring.
DO NOT use RX-8 corner seals -- they DESTROY 86-91 side housings !!!! (use 86-91 corner seals, TRUST ME).
They ARE lighter than 89-91 non-turbo rotors, have higher compression, and are less expensive.
With all of the above said: We have YET to attain even the SAME horsepower on the dyno as we are getting from our race engine(s) using the 89-91 non-turbo rotors !!!
Potentials:
With the RX-8 rotor having the side seal further outboard, we were able to increase the (ported) intake opening timing versus the earlier rotors -- it may be too much ??? (does not seem likely)
Running the rotors with the angle cut for intake opening may also be in the above category.
We always set pre-92 side seal clearance at about .0015 (1 1/2 thou). The SMALLEST clearance we could get, using the LONGEST of the available "pre-sized" RX-8 side seals was about .010 (10 thou), with the worst on this set of rotors of about .016 (16 thou). This gives a much lower "sealing" than we like.
Other than the above, at this time we are not at all sure why the power is less than when using the earlier rotors.
No, we have not done the REAL test -- run the SAME engine on the dyno, and only swap the rotors (backwards, then normal). That equals three builds, and
three full dyno on-and-offs + dyno sessions.
The "response" I gave you was a copy of one I did a few months ago (which he posted on a "few forums").
I have an "update" since that original response -----
We took the "RX8 Rotor" engine apart (having MASSIVELY over-revved it when the trans broke in practice -- probably hit 14-15k at least, AND did it 3
times. Broke a few tension bolts, cracked gears, spun a bearing, etc. but
still ran the whole Thunderhill Double National weekend!!).
We ran it on the Dyno (dyno had been up-graded to full computerized) before taking it apart (did not know how much damage had been done). Rebuilt it, AND changed the porting some, AND used 89-91 rotors, ---- AND
got about the "same" low power !!! REALLY puts a question mark back on/about the RX8 rotors.
So --- WE still have not seen any MORE power from them, but WE are seeing (WITH the porting we had been using) "about" the same power ??????
Obviously, more testing needs to be done.
Dave Lemon ---
Not having ever worked on a rotary, I couldn't correctly speculate, but from what I can tell, they're atleast the same as S5 rotors in a performance sense, but they are significantly cheaper, except upgraded seals are a must
Old Jul 12, 2004 | 04:12 PM
Fatman0203's Avatar
Re: Dave Lemon re: Renesis Rotors in 13B
I dont see why because the apex seals never see the side exhaust ports, the side seals is what has to see them. BTW why did they change the bearings? Why do they want to go higher than 10k? rpm
Old Jul 12, 2004 | 04:39 PM
Lasse wankel's Avatar
I am using the RX-8 rotors in a PP motor i built for rally. It peaked about 8 hp more and gain 10-15 more hp in the midrange. Milled the apex groove to fit 2 mm Hurley race apex and also side clearnced the rotor land though the step was at some points to small. I also found when i balanced the rotors that one side of the rotors was 10gram to heavy so we "zeroed" the rotors (FC-FD rotors is normally only 1-2 grams off "zero" Also intersting to see was that the rotors had no balancing holes on the rotorland compared to all other rotors i have seen. Also measured the Rotorbearing clearence and found them to be at 0.07-0.08 mm just as the race bearings, but the RX-8 rotors had no deep groove so i made that mod to them.
Old Jul 12, 2004 | 07:29 PM
peejay's Avatar
Old [Sch|F]ool
Even if there are no HP gains, there *should* be accelerative gains since there'd be less rotating weight.
And they're also cheaper.
Old Jul 13, 2004 | 12:23 AM
88IntegraLS's Avatar
Displacement > Boost
Maybe they reached the point of diminishing returns of higher compression ratios for the type / grade of fuel they are using.
Old Jul 13, 2004 | 07:09 AM
When i dyno'd the PP motor i used Swedens highest standard fuel 98 octane don,t know if it's comparable to US 93 octane. Otherwise the timing was 21 degree leadig with a 6 degree split to trailing no ping and knock occured other than more power from every degree i map in!
Old Jul 13, 2004 | 07:10 PM
There is 100 octane aviation gasoline, but I'm not sure if it is comparable to sweden 98. Some of the built autocross cars I've seen run aviation fuel; it has a distinctive smell to it when burned.
Old Jul 13, 2004 | 07:11 PM
peejay's Avatar
Old [Sch|F]ool
Sweden 98 = about US 94-95.
Old Jul 14, 2004 | 12:01 AM
RETed's Avatar
That sounds like a royal pain in the ***...
-Ted
Old Jul 21, 2004 | 02:45 AM
tweaked's Avatar
I have been interested in using rx8 rotors before they were released. but after their debut, I asked the guy at the parts counter and he said they wouldn't even come close to fitting in the 13b. so I gave it up. this is good news. I happen to be planning my new motor for my 88. I will have to call some tuners soon to see what they are doing.
MazdaspeedR1
The Bad & Fugly Businesses
27
May 22, 2018 05:58 PM
Ian_D
Oct 14, 2015 12:31 PM
ZacMan
Sep 19, 2015 09:20 PM
Ian_D
Sep 6, 2015 10:38 PM
