Header geometry
Old Jul 9, 2004 | 01:35 AM
88IntegraLS's Avatar
Displacement > Boost
Header geometry
To those of you with NA and / or supercharging experience, not necessarily on rotaries . . .
What is the advantage of having a header pipe travel straight off an exhaust port for a few inches before making a bend?
Is there any potential power gain involved in cutting a Racing Beat header and splicing in some 3" straight pipes between the port flange and first bends?
TIA
Old Jul 9, 2004 | 02:28 AM
rotarygod's Avatar
Rotors still spinning
You need to see it on a flowbench to understand. By having the air turn immediately after it leaves the engine, flow is disrupted which creates turbulence. However this turbulence actually is in the engine port opening itself. It sounds a little strange that it works this way but Paul Yaw discovered this on his flowbench. By running the exhaust for at least 3" out of the engine, this turbulence was gone and more flow was achieved. Neat little trick.
Old Jul 9, 2004 | 07:41 AM
Thanks. I'm probably going to attempt to splice in some 3" straight tubes off the flange of my header the next time I have it off. The only challenge will be bending the rest of the header to line back up with the rear half of the exhaust system and clear the transmission tunnel.
Old Jul 9, 2004 | 11:09 AM
RETed's Avatar
Most people will tell you 3" is overkill.
-Ted
Old Jul 9, 2004 | 11:13 AM
MikeLMR's Avatar
'Last Minute' Rallying
I thought a diameter and half after a change in section was pretty much standard to allow the flow settle down again. so 3" sounds about right
Old Jul 9, 2004 | 12:25 PM
carx7's Avatar
Ah, I'd heard the rule, but never really bothered to understand it and now I do. Makes perfect sense.
Thanks
Chris
Old Jul 9, 2004 | 01:48 PM
RETed's Avatar
Oops, I thought he meant 3" ID pipe.
I read it wrong - mah bad.
-Ted
Andrew7dg
Aug 6, 2017 01:41 PM
