550hp from a 20B w/ sequential twins?
Old Jul 8, 2004 | 05:56 PM
FDNewbie's Avatar
Sponsor
Question 550hp from a 20B w/ sequential twins?
I always thought the twins on the cosmo were smaller than the FD's, and they didn't make much power...(made for only what...6lbs of boost?)
I was looking on Pettit's website, and I saw his Banzai 3-rotor is making 550 HP @ 7500 RPM and 460 Lb-Ft @ 5500 RPM on 2 sequential turbochargers...
Is this possible on the cosmo stockers? Or is he using different twins (granted the only other sequentials I know of are the FD's, and I heard they won't fit at all onto a 20B...)??
Old Jul 8, 2004 | 06:29 PM
Swolbynos's Avatar
Newb
non sequential stockers.
an FD has hitachi ht-12 i think and the cosmo has a 12 and 15.
someone correct me if i am wrong.
Old Jul 8, 2004 | 07:14 PM
FDNewbie's Avatar
Sponsor
Yea one's larger, and one's smaller. I saw that on a thread yesterday. But the compressor wheels are smaller than the FD's from what I understand.
As for sequential or not, check out http://www.pettitracing.com/sections/Banzai.html
It's written in BOLD letters halfway down the page...SEQUENTIAL twins...so...??
Old Jul 8, 2004 | 07:59 PM
94RHDFD's Avatar
Formally 20b 3rd gen
They are REWORK'D stock twins
Old Jul 8, 2004 | 08:02 PM
FDNewbie's Avatar
Sponsor
could you elaborate on that some?
Old Jul 9, 2004 | 01:24 AM
RETed's Avatar
Cosmo 20B uses HT10 and HT15.
-Ted
Old Jul 9, 2004 | 01:30 AM
FDNewbie's Avatar
Sponsor
And Pettit uses...?
Old Jul 9, 2004 | 07:18 AM
DMRH's Avatar
This starts to get tricky when you compare numbers between the JC & FD engines.
Despite what the specs say, the FD turbos are physically larger than the JC ones.
The front turbo on the JC is similar in size but the rear turbo is tiny compared to the FD
RE-Amemiya have done extensive tests on the 20B engine & found that 450hp is the max (reliable) power achievable with the limiting factor being turbo flow.
This is with 1-bar boost. Any more than that & these turbos will **** themselves in a matter of hours (of boost time..)
Seen it happen on a JC Cosmo with my own eyes & this guy was running just 1.2-bar of boost. Turbos spat the dummy & killed the engine within 500km of driving
Old Jul 9, 2004 | 09:54 AM
FDNewbie's Avatar
Sponsor
At the risk of redundancy, that's pretty much what I thought...that you weren't going to be making more than 450 w/ the stockers. But Pettit's website clearly states/boasts 550HP with 2 sequential turbos...so he's gotta be using a different set of twins??
Old Jul 9, 2004 | 10:42 AM
WHIPSrx7's Avatar
DRFTRX7
Would this be on a stock engine??? If the engine had a decent-sized port on it and there were clearance rotors, etc...it could probably hit 550hp @ the wheels. As far as what turbos they use, that is of question. I don't think 12.5lbs is that much for most turbos, is it?
Craig
Old Jul 9, 2004 | 10:44 AM
FDNewbie's Avatar
Sponsor
Yea I would hope & expect that they did engine work...not just a swap.
I believe I read somewhere the Comso twins are only good/meant for something like 6 lbs...(remember the Cosmo was a luxury car). So 12.5 lbs would definitely be well out of their efficiency range, if what I read is correct...
Old Jul 9, 2004 | 10:46 AM
Red-Rx7's Avatar
Administrative Me
The 550 HP is FLYWHEEL and it is as 14.7 PSI on a ported engine.
Old Jul 9, 2004 | 10:53 AM
FDNewbie's Avatar
Sponsor
So it's making what...480 @ the wheels? And 14.7psi on the Cosmo stockers??
Old Jul 9, 2004 | 11:37 AM
felix_is_alive's Avatar
i believe the turbos are balanced ,blueprinted and ported, or some **** like that , ....with a good streetport and properly tunned engine ...yeah why not
Old Jul 9, 2004 | 11:46 AM
FDNewbie's Avatar
Sponsor
Is it me, or every performance mod we do on the FDs seems to see the twins as the limiting factor?
On 13B-REW's, you can't make more than 400 on the twins...for more, ya gotta go single. On the 20B, you can't make more than 480 on the twins...for more, ya gotta go single.
What's the deal? Those of us who are suckers for twins just can't have our cake AND eat it too, can we??
I wonder how much work it would be (if it would work at all, at that) to try and fit the FD stocker twins on a 20B, and get some nice power out of it...??
Old Jul 9, 2004 | 03:30 PM
Red-Rx7's Avatar
Administrative Me
Pettit claims they do something to the turbos. I believe it has been discussed quite often before.. Search, for I think someone previously posted some detailed information on them.
Old Jul 9, 2004 | 08:27 PM
FDNewbie's Avatar
Sponsor
My bad...i'm BRAND SPANKIN NEW to the 20B forum. And after seeing (realistically) the costs, I'm probably leaving real soon too! lol. (I read it could be done for $15K, little did I realize that was for JUST the swap...)
I did search, and I came up with this...
Originally posted by Kurgan
Pettit offers an upgrade and rebuild of your 20B stock turbos to utilize S5 T2 compressor wheels. This runs $1800.
Originally posted by mmaragos
I found out a little more...
The primary is larger, with flat turbine blades. The secondary is similar to the 13B-REW (in size and blade config).
I have read that the stock boost on a Cosmo is .7 bar (a little more than 10 PSI). Not too sure if that is correct.
Pettit changes the stock 20B turbos to non-sequential and turns to boost up to 14.7 psi to get 550 HP.
Originally posted by capt. bill1
Thanks for the replies. I am in and out of town a lot right now so only get back here every 3 weeks or so.
I was at Pettit and Cam said he runs his conversions at 8-10 psi of boost in a nonsequential mode. He said he has found higher levels of boost to hurt longivity. He also said he is looking at using a single turbo setup in the near future.
And again Pettit's website clearly states 550hp on sequential twins...so all this conflicting info has left me scratching my head....(I can't believe we don't have a smiley for that!)
Old Jul 10, 2004 | 12:30 AM
Fatty_FC3S's Avatar
Well, i can answer one of your questions with this....
And since when is having a single turbo 20B NOT having your cake and eating it too!!!???
Old Jul 10, 2004 | 12:34 AM
FDNewbie's Avatar
Sponsor
Fatty_FC3S, thanks for the icon lol. I dunno why I didn't see it...
...When you're a hardcore sequential twins fan...
Old Jul 10, 2004 | 12:57 AM
Red-Rx7's Avatar
Administrative Me
Whats the point of sequential twins? Meaning, why the desire?
Old Jul 10, 2004 | 03:03 AM
WHIPSrx7's Avatar
DRFTRX7
No no. It was at 12.5psi...do you even know what engine/company I'm talking about???
Old Jul 10, 2004 | 11:09 AM
Red-Rx7's Avatar
Administrative Me
What?
I am not sure what you are talking about, but I am talking about Cam's (Pettits) conversion. The 550 BHP is from their ported engine @ 1 bar of boost.
Old Jul 10, 2004 | 12:14 PM
FDNewbie's Avatar
Sponsor
Awesome low end response...no large wait for spoolup, and of course, it being just so unique...
Old Jul 10, 2004 | 12:32 PM
Red-Rx7's Avatar
Administrative Me
Yes... but a matched turbo to your porting will do the same; with higher top end HP. But, I guess you loose the "unique" thing your wanting.
In all honestly, I bet there are more 20b conversions with the twins than singles. Why? People can't afford to go all out after the conversion. The twins came with the package. A new turbo setup will cost them on average another 4-5k.
Old Jul 10, 2004 | 01:19 PM
FDNewbie's Avatar
Sponsor
Yes, it'll give you the same if not more hp, and a lot more top end...but I still beleive you'd lose a nice bit of low end, and like you said, it's definitely not unique.
Don't get me wrong, if I wanted to make some unbelievable #s, I know a big single is the only way to go. But that's not my aim, and I just don't see singles as being anything special. It's the way that almost everyone takes...even kids in Neons and Civics.
As far as cost, I'm not worried about "extra" costs at all...seeing that I can't afford the 20B conversion done "right" as it is. Maybe in a couple of years...
